1BYTE load going from 330 to 20? Logging rate Hz?
Old Aug 28, 2009 | 10:20 AM
R/TErnie's Avatar
I know there is some multiplication factor in Evoscan and EcuFlash to change the load calc. I don't remember where the thread is that explains how to fix this... I couldn't find it. Can someone tell me how I can keep my load from resetting back at zero after I've gone "off the top?" I'm hitting a 1 byte load of 360-370, but it's resetting after 330 load. Moderately annoying, but I'd like to fix it.
Also,
what dictates my maximum logging rate? I'm currently logging at approximately 200ms (5Hz) which is QUITE SLOW. I'm buying a new computer now and I need to know what I should "load up" on.
RAM? Processor Speed? Hard Drive memory?
Thanks in advance!
-Eric Urness
Old Aug 28, 2009 | 10:43 AM
fostytou's Avatar
EvoM Community Team
Processor and then RAM (but only if you don't have enough)
Change your 1 byte load factor from 1.3 to 1.4 in both the rom and evoscan. This will get you up to 357 load (255 * 1.4)
http://evoecu.logic.net/wiki/TephraMod#1_Byte_Load
and 1000x in all of the tephramod threads
Old Aug 28, 2009 | 01:50 PM
R/TErnie's Avatar
thank you Fost.
What kind of resolution do you get while logging?
Old Aug 28, 2009 | 02:09 PM
fostytou's Avatar
EvoM Community Team
As explained in the link, this is a scaled version of the load value.
Each logged item carries a value 0-255. You multiply by your scaling factor (1.4) to get the extrapolated value.
Ergo, your resolution will be in increments of 1.4 load units.
mplspilot
Dec 5, 2016 03:29 PM
Seijuro
Mar 20, 2010 11:53 AM
tephra
Nov 21, 2009 11:20 AM
roger smith
Aug 31, 2009 10:07 PM
l2r99gst
Mar 23, 2008 01:16 AM
