Grimspeed EBCS Testing
Old Sep 16, 2009 | 03:45 PM
maperformance's Avatar
So I had a chance to test the new Grimspeed 3-port Electronic Boost Control Solenoid on a Evo X MR this weekend. I want to thank Smanders for all the new logs and the time for testing. Here are some logs to show how it well it works!
I think this unit works very well to plug right into the stock harness and be able to control boost from the stock ecu!
Old Sep 16, 2009 | 06:32 PM
mlomker's Avatar
I had thought about buying one but it disappeared from their website under Evo X (they have it listed for the 8 & 9). I ended up ordering a Perrin instead.
Old Sep 17, 2009 | 07:28 AM
How has it worked out for you?
Old Sep 17, 2009 | 02:06 PM
BigT's Avatar
I haven't seen any 3 ports that have impressed me yet. I can hold similar boost to your post with just a GST boost pill accept after 7k where it falls to 18.5 at 7500rpm. But, with the right tune, you'll make more power by compensating mivec and timing after 6k rpm vs maxxing out the little turbo. I think 3 ports are more for those with bigger turbo's.
Old Sep 17, 2009 | 02:42 PM
They will work with the bigger turbo a little better. But with using timing and mivec to make up the power it does push the engine a little hard! Any Mivec over 6500 is pointless to be adding to me!
Old Sep 17, 2009 | 03:11 PM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Chris is right if you have a stock turbo it will be hard for it to hold big boost.....larger turbos like the red will have no problem at all
Old Sep 17, 2009 | 03:29 PM
I would take 20psi at 7k for 99 shipped over stock 15psi at 7k any day of the week! Im sure Smanders will agree with me!
Old Sep 18, 2009 | 12:31 PM
boostdog's Avatar
Do any of you use the GM 3 port bcs?
Old Sep 18, 2009 | 09:14 PM
smanders's Avatar
Its crazy to me how much this car now pulls to the redline. I'm so use to turbos running out of gas after 5500 rpms. Not any more with this EBCS.
Old Sep 18, 2009 | 10:36 PM
Dre1189's Avatar
that is sick
Old Sep 21, 2009 | 06:06 AM
DBallz's Avatar
Chris I will probably be ordering one in a week or 2 and I think with the mods on my car it should be fun tuning I will so a base pulls and then do the install and get to tuning I know my tuner will be able to make the boost nice and smooth
Old Sep 21, 2009 | 07:25 AM
IMPORTIMAGE's Avatar
nice info!
camo_vw
Northwest Region
Sep 26, 2016 07:47 AM
shunderwunder
Jul 17, 2012 06:31 PM
maperformance
EvoX 'For Sale' Suspension / Brakes / Handling
33
Jan 17, 2012 08:07 PM
black_beauty
Nov 21, 2011 07:41 AM
