LED's
LED's
Whats a website where I can get LED's for cheap...all im doing is looking to replaec my interior door lights to LED lights instead might add other LED lighting but just looking for that at the moment...and anyone know what a decent front lip cost and where I can purchase one and what is the better a cold air intake or short ram intake and which model to buy....thanks
Cheap price = Cheap quality
If you want something good , its not going to be cheap .
If you do want to do it right check out www.V-leds.com .
I currently have an injen cold air intake. I think cold air intake is better. While short ram gives u about 7 hp, cold air gives u about 9 or 10. Its not much of a difference at all, but cold air helps a little bit more. However, with cold air, you have to be careful about rain and puddles. The location of a cold air is low on the car, so a big enough puddle, and not taken carefully, you can flood your engine. but dont worry too much, ive had mine for about a month, been through rain, and even puddles (carefully of course, avoid if u can), and no problems as of yet. If you can spare the extra bucks (about $35), i would invest in a hydro shield. Its a very tight mesh that blocks practically all the water from entering the filter. Unless you completely submerged the air filter (which wuld b dumb), you should b fine. as for brand, Injen, i love it. for pics, check out my garage gallery, https://www.evolutionm.net/forums/ga...ancer2008.html.
^^^ cool story bro.
sorry my bad, thought that he just wanted led info
does anyone know the number code for the HVAC control light
Last edited by SYSTEMA; Apr 26, 2010 at 06:24 PM. Reason: at the risk of sounding like a d-bag
cai consistently have higher hp gains than short ram intakes, but they are also alittle more pricy.
if you do go with the cai you just need to keep an eye out for hydro lock, as ace already stated. but if you get a hydro shield and a bypass valve you should be alright. aem makes one and if you need more info on how the valve works try here. \/\/ http://www.modified.com/tech/0104scc...lve/index.html
t5caveman
Apr 7, 2012 10:10 PM
