Sponsored by:
Sponsored by: CARiD
OEM Parts
Old Mar 30, 2010 | 02:09 AM
4080wrx's Avatar
OEM Parts
Hi....
I am currently stationed in Korea and I am having a hard time coming across OEM Mitsubishi parts. Recently I did my 12,000 mile oil change and I had to order online an oil filter because all the stores here did not have any since Mitsubishi's are not sold here. Basically what I am looking for are some websites that you have used and recommend that ship to APO addresses (military overseas addresses). any help would be greatly appreciated since I would like to be prepared for my 15,000 service, which if i remember correctly calls for the transfer case fluid to be changed.
Car info:
2008 Evo X MR
Old Mar 30, 2010 | 02:33 AM
MyEvo8Urs's Avatar
Not many will ship to APO, what do you need? Maybe I can help.
Old Mar 30, 2010 | 06:01 AM
4080wrx's Avatar
I am going to need the following items for a 2008 EVO X MR for future maintenance services:
-Trans Axle oil...Mitsubishi genuine Dia-Queen new multi gear oil SAE 75w-80 API GL-3 (3 quarts)
-TC-SST oil...Mitsubishi genuine Dia-Queen SSTF-I (6 quarts)
-Transfer oil...Mitsubishi genuine Dia-Queen LSD Gear oil (1 quart)
-Rear axle oil (for differential)...Mitsubishi genuine Dia-Queen multi gear oil LS
-Rear axle oil (for torque transfer mechanism)...Diamond ATF-SP III
-Cabin filter
I think thats about it, my god i just realized this car uses so many different types of lubes...
Old Mar 30, 2010 | 06:53 AM
Mendo's Avatar
IMO skip the SST Mitsu Dia-Queen and go for some SSP Pro Red fluid, stuff is amazing.
Old Mar 30, 2010 | 07:25 AM
Brokenevo's Avatar
try Justin, he is a rep for Lancershop.com on here. Send him a pm Lancershop.com is his user name on here.
Old Mar 31, 2010 | 03:18 PM
4080wrx's Avatar
bump....
anyone else with any ideas?
Old Mar 31, 2010 | 03:25 PM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
hit up Russell on here
https://www.evolutionm.net/forums/me...-russellm.html
he is the evom contact for mitsubishiparts.net
he uses priority usps as far as i know so he COULD ship to a apo prolly if company policy allows and he is awesome to deal with a good prices/knowledge of what he is selling.
Old Mar 31, 2010 | 03:35 PM
stokEd's Avatar
You don't need this, it's the tranny fluid for the 5-speed.
And FYI, this is going to require a trip to the dealer to have the system bled using the MUT tool.
Old Mar 31, 2010 | 04:03 PM
monkey_187's Avatar
If you are in the military this will be your new best friend, enjoy
http://www.apobox.com/
Old Mar 31, 2010 | 04:31 PM
LaXGSR's Avatar
Actually for the ATF in the rear diff (about a half quart), you don't need to have the system bled using the MUT tool from what I understand. The bleeding is only necessary if you disconnect the whole system, which has a total capacity of over 7 quarts of ATF.
Old Apr 1, 2010 | 12:37 PM
MAS2377TECH's Avatar
From: Philly, Germany, Japan, UK...South Dakota (Da Sticks).......
Shipping parts should be no problem for an APO, I used to get my parts shipped to England all the time - it took a little bit longer though. Fluids are a problem seeing that they may burst during impact (like dropping or a strike) make sure they put plenty of packing peanuts in your shipment. Just speaking from experience.....
Old Apr 1, 2010 | 12:53 PM
goofygrin's Avatar
Use Diaqueen only in the transfer case. I swapped to Amsoil last year and that was a mistake. The transfer case REALLY likes the diaqueen a lot better.
Old Apr 1, 2010 | 12:54 PM
atombomb33's Avatar
EvoM Community Team
This.
Russell is your guy. I've ordered stuff from him for both my IX and X and have always been very happy with the service and prices
Old Apr 1, 2010 | 12:56 PM
LaXGSR's Avatar
goofygrin, what were the affects of running non-Diaqueen LSD in the transfer case? Whining? I've heard the same and have stuck to Diaqueen LSD for every part that calls for LSD fluid.
Old Apr 1, 2010 | 02:35 PM
stokEd's Avatar
Isn't the rear diff part of that system? Could you explain, I'm confused.
