Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
cruise control not working how to
Old Jul 30, 2010 | 12:44 PM
smokem22's Avatar
Question cruise control not working how to
does anyone have a how to write up for how to get the cruise control working. I installed the LED brake lights and now i have no cruise control.
Old Jul 30, 2010 | 01:34 PM
Defcon5Es's Avatar
yeah! I heard it does that when you installed those LED taillights. I think the reason why your cruise control is not working is because of a blown fuse. Not sure though.
Old Jul 31, 2010 | 09:21 AM
kalpakiotis's Avatar
you can try putting a resistor in. If you had a blown fuse, the tail lights shouldn't work either.
Old Sep 6, 2010 | 01:21 PM
smokem22's Avatar
where would i put the resistor at?
Old Sep 7, 2010 | 04:11 AM
in series with the LED lights, not sure how big though without having a set to play with.
Old Sep 7, 2010 | 04:17 AM
Jogenmaru's Avatar
So would this be different for 7th gen lancers as well. I have 7443 spider light led's for my rear lights but there isnt a blow fuse. Could I be missing something.
Old Sep 9, 2010 | 02:15 AM
smokem22's Avatar
so i would need to have a seprate resistor for each led light or just the brake light?
Old Sep 9, 2010 | 04:19 AM
Depends on how the circuits are set up. I have never played with them because I have yet to be able to find a clean way to take apart my rear lights to make them LED. But if only the brake lights are tied into the CC, then only the brake lights would need a resistor to simulate the stock brake lights. If more lights are tied in, each appropriate light would also need a resistor to simulate the original.
An easy way to size the resistor is to use the ohm reading on a DMM and measure the stock lights. The LED lights plus the resistor should equal to this reading. Another way to do it is by matching the power of the old lights to the total power of the new lights and LED lights. V = IR.
GL
Old Sep 9, 2010 | 07:18 AM
smokem22's Avatar
hope this helps found it while searching google.
http://www.autocityimports.com/image...-Resistors.pdf
Old Oct 21, 2014 | 04:47 PM
HotPinoy's Avatar
Hi I installed and change all my bulbs to led..my turn signal has a resistor..does that mean i have to hook up for each brake lights for my cruise control to work...I just notice its not working when I went out this weekend for a long drive....
Old Oct 21, 2014 | 07:24 PM
CamShaft's Avatar
Give this a try and get back to us.
File Type: pdf
Old Oct 22, 2014 | 08:08 AM
HotPinoy's Avatar
Hi hanks for the flash code..I will try it and post the result...
Old Aug 2, 2021 | 06:10 PM
OZ-driver's Avatar
Sorry for the zombie thread! I have an 03 OZ with the cruise control not working. I tried a few times to get the flash codes to read, but it's not flashing anything. The green "cruise" comes on, so the bulb and fuse are good. If it's not flashing, I'm presuming that perhaps some of the contacts within the switch are bad? It's worked off and on for a month or so, but just won't engage at all now. Getting opinions before buying a new switch, or taking the car in. Thanks!
Calicab
Lancer How Tos / Installations
18
Apr 2, 2015 08:55 PM
H8ted1488
Dec 21, 2014 03:00 PM
gridiron44
Jun 5, 2010 10:30 PM
plokivos
Jun 25, 2004 11:41 AM
