Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
toggle swith ignition
Old Apr 21, 2011 | 05:44 PM
cali11b's Avatar
I dont know if anything like this has been posted before but if it has sry and pls oint me i the right direction. Anyways I want to replace my ignition with a toggle switch, is this possible? and if it is how would i go about doing that? thanks for any advice.
Old Apr 21, 2011 | 09:08 PM
RonPattonJr's Avatar
so like a push to start.
Old Apr 22, 2011 | 07:45 AM
cali11b's Avatar
yea i gues in a way it would be like a push to start i just dont know if thats possible or how to do it.
Old Apr 23, 2011 | 09:15 AM
CamShaft's Avatar
anything is possible, but just from the sounds of it, you would either need two switches, or a 3 stage momentary switch...you need to have one stage of the switch(or one switch) to supply the proper circuits with battery voltage, EI, instrument cluster ECU, EECU, radio ECU, ect. Then you need the next stage of the switch(or the other switch, make sure this is a momentary switch also) to supply voltage to the starter relay.
Is it worth it? I am a pretty good wiring expert on vehicles, and I would say its not worth my time, but if it is worth yours then... get a wiring schematic and a proper switch/switches then draw it out on paper (your personal schematic, in case something every f*cks up) then wire.
Good luck on this one
Clutch450
Nov 1, 2016 11:30 AM
GeoMitsu
Jun 19, 2016 04:16 PM
ezio
Mar 27, 2016 08:16 AM
HKSevolutionNYC
Nov 26, 2015 11:45 AM
i786533
Mar 19, 2009 05:00 AM
