Sponsored by:
Sponsored by: CARiD
Why does my car jerk in 1st Gear?
Old Dec 10, 2012 | 10:20 PM
mj0917's Avatar
Car has 20k, jerks forward when leaving a parking lot or driving in traffic. Only happens sometimes. No mods by the way. Anybody out there with similar problems?
Old Dec 11, 2012 | 03:48 AM
HDGamer's Avatar
Well 1st can be pretty violent. You need to be gentle with the gas in 1st
Old Dec 11, 2012 | 06:38 AM
Johnr352's Avatar
MR or GSR. See if it's a GSR you have a clutch thingy and a shifty thing and you have sort of slowly transition letting the clutch out while pushing on the go peddle slightly, do it too fast and it is jerky.
Just kidding. Need a little more information... GSR or MR? original clutch I presume? Change your brake fluid recently?
Old Dec 11, 2012 | 11:49 AM
imjuspIayin's Avatar
Any manual car I have ever driven has been jerky in first gear. I only stay in first while accelerating or maintaining speed. If I am going to slow down I either do so in 2nd or put the car in neutral.
Old Dec 11, 2012 | 05:43 PM
lowkey's Avatar
Registered User
It's just champing at the bit. It wants to run free.
Old Dec 11, 2012 | 06:14 PM
EvilRob's Avatar
Is this your first manual car? Serious question no sarcasm intended.
Old Dec 11, 2012 | 07:38 PM
mj0917's Avatar
no...and I never dump the clutch or floor it in 1st gear either. like i said this only happens sometimes, but it's annoying and my passengers think i'm doin it on purpose
Old Dec 11, 2012 | 07:54 PM
►EvolutionX◄'s Avatar
Torquey (sp?) *** engine + short 1st gear + awd = lot of things jumping around if you don't finesse them.
Old Dec 11, 2012 | 08:45 PM
Sev's Avatar
Sev
Sounds normal to me. If you're in first gear and you are pressing the gas slightly to move it shouldn't jerk. But when you come off the gas in 1st gear it will jerk. That's just how it is. People look at me like I'm in idiot in traffic when I can't get to 2nd gear.
Old Dec 11, 2012 | 09:22 PM
Windforce18's Avatar
If I'm stuck in traffic moving in first and can't really get to second, my car will jerk. Usually I'll just push the clutch in and let it roll or put it in neutral.
Old Dec 12, 2012 | 04:26 PM
CainEvoX's Avatar
my car used to jerk violently in 1st and would also over boost and throw the asc service light. I got a cobb ap and started running a lwg map. no more issues
Posted from Evolutionm.net App for Android
Old Dec 12, 2012 | 08:49 PM
MAS2377TECH's Avatar
From: Philly, Germany, Japan, UK...South Dakota (Da Sticks).......
Evos are tempermental. My VIII was and so is my X. I'd work on the foot work and change the shifter bushings.
Old Dec 12, 2012 | 09:11 PM
Yoo Shin's Avatar
I tried the lwg maps but lost a good but of boost, so I switched back to the Beta 1.8. A little extra throttle and a tad more clutch slip avoid the jerky stutter. I need to try the latest beta version too see ififit's smoother and pull some data.
Old Dec 13, 2012 | 06:54 AM
NODAKevo's Avatar
I've seen the way you drive, you've got a HEAVY FOOT! You'll blow yourself to bits!
Old Dec 19, 2012 | 08:59 PM
CainEvoX's Avatar
I still hit 25.6 with the sf stage 2 lwg
