SST - Down shifting
SST - Down shifting
Hey Guys,
Just wondering.....I have a question with regards to the time involved when you you shift the paddle shifter ( or floor shifter) to the time the \SST actually shifts its gear. I am not questioning the speed of the actual shift ( which is lightening fast) but the time involved from human input to actual gear change.
Since just about day one I have noticed a good 1 second DELAY from selecting the gear via paddle or floor shifter to the actual gear change, it is more apparent from gears 1 to 3 starting from a standhill. Is that a problem? or am I just being too picky. I wanted to know if you RA owners out there have this same situation. I would not say its a problem but I really wanted to find out if this is the same experience with you guys out there. Based on what i hear on this site here, i may go the dealer to bring up the issue.
Hmm so that 1 second delay is what a manual shifter has on us. Does that even out the playing field between total shift times. You would think that there may be a fix for that ( thinking that its electronic) No to be an *** or anything but what good is a super quick dual cluth tranny is if when you ask for the gear change its takes a a good second..
What are you talking about? If you try and short shift it will delay to a certain rpm. Other than that, when I hit the paddle it shifts immediately.
Normal or Sport mode? Under load or coasting along?
For the record there is no delay if you do not gas it hard but there is one if exercise most of your right foot of the line.
Thanks for your input
Have a peek at this thread. It's on the EVO MR, but same gearbox:
http://www.evoxforums.com/forums/showthread.php?t=13197
Just because its electronic doesn't mean there is no delay. You still have to have time for the clutch to engage and switch gears.
The issue described in this thread and the one linked above is about the delay before the command to shift is executed - NOT how long it takes to actually switch clutches. It's not about a slow shift but rather am intermittent delay before the shift is initiated.
I feel the same. The 'actual shift' is excellent quick especially in Sport mode, but I am disappointed in the delay between when I 'want' it to shift and when it actually does when I touch the paddle. Under throttle load it is possible to be in the red line even though I have pulled the paddle well before the tach needle has reached it and when the computer finally tells the transmission to do it's thing. I find I am 'anticipating' the delay when it will shift in addition to my brain saying ok pull the paddle.
