When to change SST transmission fluid?
Old May 26, 2009 | 08:21 AM
tsbevo's Avatar
According to the maintenance manual, even under severe maint. schedule, the SST transmission oil should be changed at 30K miles. But should I be changing earlier? If so, when and at how many miles?
Also, are there instructions on how to check and replace the transmission oil?
Old May 26, 2009 | 01:32 PM
jrsimon27's Avatar
there are 3 bolts under the gearbox which you unscew to let out the oil and on top under the airbox there you check the oil level but you need to remove the airbox to see where it is.
the owners manual says to change every 30,000miles under severe usage and for normal use at 60,000 miles iam gonna change it at 30,000miles also it says to ckeck for leaks on the tranny and if you have them you need to check the oil level.
has anybody in here done this?
Old May 26, 2009 | 08:56 PM
gunzo's Avatar
yes .. and you can't check the level of the fluid from the top nut ..
You practically have to measure how much you drain out and then put back in the same amount ..
You'll see the 3 hex bolts underneath .. the closest to the front drains about 5 quarts of oil .. and the other 2 drains about 1.5quarts each ..
Old May 27, 2009 | 12:41 AM
jrsimon27's Avatar
thanks for the info gunzo,did you change the oil filter for the gearbox also?
at what mileage did you change the gearvox oil?
thanks
Old May 27, 2009 | 12:49 AM
gunzo's Avatar
thanks
.. I didn't change mine .. I changed a friend's
That was done around 20k miles .. if you track often .. change the filter too .. that filter medium is a piece of crap .. and at $130 a filter .. and expensive crap ..
Mine had an oil analysis done at 15k miles and was told everything good .. and continue to use the oil until 30k miles ..then do another test .. I had 2 track days when the oil was tested ..
Old May 27, 2009 | 10:56 AM
jrsimon27's Avatar
thanks gunzo nice info
Old May 29, 2009 | 02:18 PM
abu's Avatar
abu
Good info here, where's the tranny filter located? Thanks.
Shirish Agarwal
Dec 27, 2014 02:21 AM
Crester
Mitsubishi TC-SST Discussion
10
Apr 28, 2014 11:45 AM
princess33
Lancer Tranny/Drivetrain Tech
May 23, 2013 03:04 PM
Bojim2305
Dec 9, 2012 07:33 PM
dklau33
39
Nov 26, 2007 05:20 PM
