What's up with this?
Old Mar 17, 2010 | 01:13 PM
slo4g63's Avatar
Originally Posted by hotdog
Your text is large.
You probably exceeded the torque limit, it loled at you, and then reset itself when you got back home.
Sorry to the OP that started the thread, but that was CLASSIC!!!!
Old Mar 18, 2010 | 06:59 AM
EVSEVO8's Avatar
The dtc that was set when then cel was on should still be in memory in the ecm. Have it scanned for history codes and let us know.
Old Mar 18, 2010 | 08:08 PM
gunzo's Avatar
P1870 .. torque signal abnormality ..
Thats the CEL that doesn't cause the engine to go funky
Its not slipping .. the ecu is not tweaked for the gearbox
Old Apr 21, 2010 | 01:21 AM
luvboost's Avatar
that would make complete sense too specially with 340 hp because you can't run stock ecu with 340 so tcu is going to have the same issue if I'm reading this correctly. Specially with these cars it seems there are alot of parameters that the transmission computer looks at to make sure everything is running and functioning properly. Definitely didn't know you could tune the tcu though, great knowledge these forums possess
Old Apr 22, 2010 | 02:51 PM
GST Motorsports's Avatar
340 is far from the limit of the stock clutches on the MR with correct tuning
- Bryan
Old Apr 25, 2010 | 01:31 AM
Ray Knight's Avatar
I had this same issue and Gunzo sorted it out with some badass SST tables Now i have yet to throw another code since this tune.
Old Apr 25, 2010 | 06:33 PM
DepoRacing's Avatar
u probably had the traction on and it engaged when the power hit.
