What Is The Actual Cause of the SST Overheating?
Old Nov 8, 2010 | 10:59 AM
Crester's Avatar
I'm curious as to what the actual cause of the SST overheating at the track is? Is it the number of gear changes it's performing? Or is it the fact the parts of the transmission are spinning so fast since the revs are kept essentially above 5K rpm all the time that is causing the transmission to overheat?
Old Nov 10, 2010 | 04:45 AM
jimbo4510's Avatar
less air flow the clutchs are working harder more friction means more heat gears are getting used more often one track run is the same as 5000kms drive
Old Nov 11, 2010 | 07:42 PM
evo542's Avatar
it happens due to clutch slippage during shifting, shorter tracks with lots of turns will increase oil temperature more (due to numerous downsifts/upshifts) than a high speed track with less bends/corners
Old Nov 13, 2010 | 04:53 AM
E6-X's Avatar
remove the fog lapmps it does help to improve cooling and not only the sst temps it does al improves engine oil cooling ! adding another cooler wil also help out greatly
GhostEvo^X
Jul 8, 2017 12:17 AM
babaz7
10
Jun 21, 2017 08:00 AM
Mohannad
Oct 4, 2013 12:21 PM
Tray@Forged
EvoX 'For Sale' Engine Internals and Drivetrain
93
Dec 8, 2011 09:48 AM
RoundPro
Mitsubishi TC-SST Discussion
199
Nov 2, 2009 05:54 PM
