would random slowdown have anything to do with SST?
Old Feb 7, 2011 | 07:10 PM
bradze's Avatar
Every slow down I've ever gotten previously was on track, with current cooler setup would take 20+ minutes of on-track use in over 95F weather. Anyway I got one on highway Saturday, my friend says its not trans related. Tuner is going to try and figure it out, initial tune was fine, but has been funky since retune.
Old Feb 7, 2011 | 07:16 PM
Kracka's Avatar
Isn't it a SST-only warning for fluid overheating or other errors?
Old Feb 7, 2011 | 07:37 PM
bradze's Avatar
yes, id like to know what those other reasons are. i dont really think it had anything to do with trans but im not right very often.
Old Feb 7, 2011 | 07:50 PM
WarmMilk's Avatar
who says its not trans related? As far as I know, the slow down message is only trans related...
Old Feb 7, 2011 | 08:00 PM
mrMTB's Avatar
I personally cannot imagine how one could possibly overheat the transmission on the street... you might want to check that the space in front of your transmission cooler is not clogged up with something...
Old Feb 7, 2011 | 08:16 PM
bradze's Avatar
i have secondary cooler similar to SSP's. xMR told me "tune needs work". i believe a few other things will cause slow down, not 100% sure. i think overboost is one. he had a similar problem with his last year, im assuming this is what jon@HB Speed told him, who has supposedly tuned tons and tons of SST-equipped evos. just noticed that 1 of 3 answers are from people who own an SST
Old Feb 10, 2011 | 02:36 PM
SSP Jeremy's Avatar
It's very possible. I've seen a sst over heat from spirited street driving in sub 50 degree temps.
Old Feb 10, 2011 | 02:39 PM
Kracka's Avatar
Tom recently got the warning in his MR when he was giving Armando and I a ride to showoff the Green. He has the AMS cooler.
Old Feb 10, 2011 | 06:38 PM
bradze's Avatar
maybe, was a ricer line-up type drive which i never will do again. had a small boost leak and tune was "adjusted" hopefully no more issues
Old Feb 11, 2011 | 12:14 PM
migs647's Avatar
Aren't you still on factory fluid from when you bought the car with multiple track days? Might be time to change it.
I changed mine at 10k and it was disgusting.
Old Feb 12, 2011 | 08:46 AM
bradze's Avatar
ive changed 3 times. currently using SSP pro gold, did you sell MR?
Old Feb 12, 2011 | 11:24 AM
migs647's Avatar
Nah decided to keep the MR and get a theft recovery VIII as a track car. But that project has been put on hold since I'm doing another season of motocross.
When did these problems start? Immediately after the tune? Can you reproduce it any more? Any track days coming up that you'll be able to test at? It'd be a shame to spend that money and have slow down messages all day. You mentioned a boost leak, where was it?
Old Feb 13, 2011 | 06:09 PM
bradze's Avatar
boost leak was from wrong sized clamp on stock part of uicp. went to english wednesday, they did boost leak test and then aaron rode along and "adjusted" tune. only had issues since retune but i think im not having problems anymore. just had an autox practice today, no track days planned til april.
another question, when using launch control, if you have to hold the brake for like 10 seconds is it normal to go into slowdown? i imagine thats supposed to happen. held it at 5k revs at start line way too long, but after slowdown, seemed fine.
Old Feb 15, 2011 | 02:04 AM
phraust's Avatar
That's normal. Has happened to me a few times where the light wouldn't turn green. Car gets the slow down message but runs perfectly fine after.
Old Feb 15, 2011 | 06:14 PM
bradze's Avatar
thought so thanks
