Sst problem
Old Feb 8, 2012 | 08:38 AM
redx2008's Avatar
Sst problem
I have a 2008 x mr and wen I yes launch control I get a slow down light every time or when I accelerat hard it will hit neutral then start shifting hard but my every time I'm resivors are all full it has 50k on it and only mods a cone filter gutted cat and muffler delete no tune
Old Feb 8, 2012 | 09:17 AM
Mendo's Avatar
First learn some grammar, or at least use some periods and commas.
Second. Maybe your not launching it properly? Also for those mods I think you would need a tune.
Old Feb 8, 2012 | 09:37 AM
jkennedy293's Avatar
When was the last time you changed your SST fluid.
Old Feb 8, 2012 | 09:49 AM
eg6motion's Avatar
sounds like you are not launching correctly?
Is the engine freely revving to 5000rpm when you launch? Or is the car attempting to move, and you are only hitting 3-4000rpm?
Old Feb 8, 2012 | 09:53 AM
redx2008's Avatar
I bought the car used 43k on it I correctly use the launch control if freely holds 5k I let off the brake it takes off the hits neutral I have serviced the transmission since I purchesed the car
Old Feb 8, 2012 | 10:55 AM
Mendo's Avatar
sounds like you need a tune. get in touch with a tuner that has access to the sst tables. Kozmic27, Razorlab and some of the others can help you out.
Old Feb 8, 2012 | 11:01 AM
Since you bought it used, the previous owner could have worn out the clutch discs.
Like stated before, get a tune.
Kelper002
Mar 16, 2017 04:10 AM
Nichiren
Lancer Tranny/Drivetrain Tech
Nov 19, 2013 02:22 PM
WilliamZu
Oct 13, 2013 04:30 PM
WhItEVIII
10
Aug 23, 2010 08:23 PM
usarmy1113
Jul 29, 2010 10:09 PM
