SST fluid change by dealer but no new filter..thoughts?
Old Apr 9, 2012 | 11:39 AM
DjRags604's Avatar
I recently passed the 48,000 km mark and definitely noticing the SST is misbehaving a bit. Here in the Vancouver area most dealerships were charging about $850 for new SST fluid and a new filter. I called one dealership that said they would put in new fluid for about $350 (or $550 to include transfer oil and a few other things). However, this would not include a new filter for the SST (the one person I talked to there said they don't change the filter ever which doesn't sound right to me). I've only had the car for about 8000 km so I don't know the full warranty history (no documents when I bought it off the dealership) but I'm assuming this is the first time the SST fluid has been changed. I'd think that if I'm following dealership instructions my warranty would remain intact if something happens but it worries me when I find a price that is $500 less than its closest competitor. Any thoughts/advice would be greatly appreciated.
Old Apr 9, 2012 | 12:38 PM
Struc's Avatar
Ignore the idiot dealer. Change the filter too!
When I pulled mine, it had a good coating of muck on it. I'm pretty positive it was restricting flow.
Old Apr 10, 2012 | 04:22 AM
Supraboy1's Avatar
I change my SST filter every 7500 miles or two oil changes and the SST fluid every 15K or every 4 oil changes. The filters are 100 bucks plus labor.. you honestly do this yourself. The fluid is 300 bucks.. plus labor.. should cost no more than 350.
Old Apr 10, 2012 | 09:36 AM
RAPTR's Avatar
It interesting you dealer said this because mine said the same thing. They even told me that they don't keep them in stock because they never change them. I really hope guys are aware if their dealers are not replacing the filter.
Old Apr 10, 2012 | 04:16 PM
no-slip's Avatar
I would think that the filter would be the first thing to change after the first 5k or so after breakin, not changing the filter is like having a clogged artery.
Old Apr 15, 2012 | 12:07 AM
Crester's Avatar
I notice that the service schedule for the car only mentions changing the fluid tho... and not the filter.
For the engine oil it specifically says chance the oil and filter... but not for sst.
Old Apr 15, 2012 | 04:01 AM
evoxmrowner's Avatar
Change it, buy it give it to them .
Old Apr 15, 2012 | 05:05 AM
Supraboy1's Avatar
The EVO MR service manual clearly says in the printed material change filter.
Old Apr 15, 2012 | 06:38 AM
hotkupa's Avatar
Not only that i would mark the filter to be sure that they changed it. I just do not trust dealers.
Old Apr 15, 2012 | 10:24 AM
Crester's Avatar
Where? The service schedule I see says...
"Change twin clutch sportronic shift transmission oil"
Old Apr 17, 2012 | 06:48 AM
TrailBrake's Avatar
I was told the exact same thing by the dealer when I had my SST fluid changed. Ultimately I ended up having an independent shop order and install the filter.
Old Apr 17, 2012 | 11:56 AM
weneversleep's Avatar
Really? Where? Not in the 2008 MR official service manual, unless there has been a recent update.
The steps to flush fresh fluid through the transmission (by shifting) and then draining is supposedly their way to "clean" the filter, from what I can tell.
I changed my filter after the 2nd SST fluid change at 28K miles. Filter was black as night and completely clogged. The SST shifts much better now.
Old Apr 17, 2012 | 12:20 PM
airgazem's Avatar
The dealership's don't care, not there car its a must to change the filter anyone that says different knows nothing, would you just change the oil in the motor and not the filter? I bet you pull the filter its dirty a reason for flow restriction. That's why if you can service the car yourself you know what's going on.
Old Apr 19, 2012 | 10:15 AM
deanob's Avatar
Ive done some research on this, apparently canadian dealerships cannot order the SST filter at all so they are instructed to just change the fluid.
Your best bet is to order one from mitsubishiparts.net and either do the change your self with the filter or ask the dealer to do it and provide the part.
Old May 2, 2012 | 12:13 AM
I picked up a dodson stainless filter. No more paper crap.
