Shift feel and Turbo function between Normal, Sport, S-Sport modes.
Old May 24, 2013 | 02:39 PM
Mystykalbaby's Avatar
Question Shift feel and Turbo function between Normal, Sport, S-Sport modes.
Has anyone really measured performance between these modes. I dont know if its just the noob in me as far as being new to the evo family. in the manual shift position my 2010 MR feels the same in normal and sport mode, but if i go into S-sport mode it seams to really slam (isn't this bad for the motor mounts) the gears.
Second, I seem to have a whine of some type if I slack on throttle. not sure quite what i'm hearing almost like the sound of someone whistling through a fan. its more present in the Sport and S-Sport modes.
No Problems that i'm aware of, just learning as I go.
Stock 2010 MR approaching 55k Miles.
Old Jun 30, 2013 | 01:18 AM
Gqracer's Avatar
Normal.
Old Feb 23, 2015 | 06:03 AM
hispanicpanic's Avatar
whine is very normal. Change your sst fluid often. 30k maximum intervals. I hear stories all the time from Kozmic that SST's that never change fluid usually fall apart around the 50-70k mark. That's a 6000 dollar mistake.
Old Mar 26, 2015 | 03:30 AM
MR. EVO MR's Avatar
I noticed the faint whistling sound only happens in SS, I never hear it in Sport or normal.
It's definetly the turbo spooling very lightly.
Why only in SS??
Old Mar 27, 2015 | 05:20 AM
its not the turbo, its your gearing from the straight-ish cut gears. Our gears are more straight cut vs the 5 speed due to more positive shifts. In s-sport the clutches don't slip in part throttle application, meaning they're engaged 100%. In normal and sport, they slip a little that low, causing the gear not to be fully engaged. This makes the tq on the gear much less, providing much less noise.
Old Mar 27, 2015 | 06:03 AM
detroit pistins's Avatar
It is not unusual to experience faster & crispier shifts when you operate in sport mode. They often try to engage the clutch at a faster rate as well as bring the engine trq back to where it is supposed to be prior to the shift to allow for a smoother transition between the ratios.
IC_EVO
Mitsubishi TC-SST Discussion
21
Dec 30, 2016 08:55 PM
surinder
Feb 23, 2014 02:12 AM
Kaizen Tuning
Jan 1, 2012 03:31 PM
black E
Oct 18, 2011 09:41 AM
lousEVOxmr
Feb 12, 2010 09:13 AM
