SST Won't Shift Stuck in Gear
Old May 25, 2014 | 01:48 PM
ikt's Avatar
ikt
Originally Posted by SSPKris
I think that he must have misunderstood me about the mitsu fluid. The fluid becomes very contaminated and broken down when run for long periods of time.
Kris
SSP is the singular authority on anything aftermarket SST stuff, it's gospel. I just did an early flush based off their maintenance schedule. Props and thanks for doing all the research
Old Mar 3, 2016 | 03:54 PM
TunerES's Avatar
Did this work? I am having the same problem.
Old Mar 11, 2016 | 08:12 PM
KVandy15's Avatar
I'm not sure exactly how the pro's are going to weigh in here but in my experience thus far, if you have more than 15K miles on your fluid/filter and you are having a problem, try changing your fluid/filter first. Even as expensive as it is, it is still the cheapest solution and has at least a 50% success rate. Some guides on fluid changes will recommend a mineral oil flush as part of the process, afaik this is still the recommended flushing procedure.
Although, it would be nice to hear what the big boys are doing these days. I don't think I've seen any significant updates on this front in years. Maybe @Kozmic27 or @SSPKris wants to tell me I'm wrong?
jadeboy
Sep 26, 2016 10:06 PM
glen villis
Aug 29, 2016 08:49 PM
rydogg008
May 23, 2016 03:27 PM
mxc1868
Mitsubishi TC-SST Discussion
Mar 26, 2016 02:35 PM
evo tracker
Southeast Region
Feb 15, 2016 08:28 AM
