Big torque on SST trans, what upgrade
Aside from a very good clutch upgrade, what else an SST trans need to survive to a GT3584RS on E85, and 35/40psi of boost?
The engine is currently under build, so this is the best moment to upgrade also the gearbox.
No one in Europe should be allowed to touch besides J-Spec in Switzerland. If you call Olivia at J-Spec, she'll get the trans components that need modification to me so I can set it up, and her shop can put it back together and have it work when they are done. That will be less costly than shipping the entire transmission to the USA, though if thats what you want to do, J-spec can manage that for you also. If you make the power that set up can make, you will need a custom clutch and some valve body work.
pbassist12
Sep 30, 2011 03:16 PM
AssaulTECH
Evo 'For Sale' Suspension / Brakes / Handling
148
Feb 24, 2010 03:39 PM
