Launch Control not working?
Old Jan 23, 2021 | 09:30 AM
jrsimon27's Avatar
Ive done a ton of search but dont understand exactly what tables using ecuflash you have to tune and how to get launch control to work properly. Since i got my car modded with ets open air filter a catt delete an a crushed diverter valve i have not been able to launch it again.
I take off asc and hold for 5sec till it beeps.
then put car in s-sport i leave it in automatic
i press the brakes really hard left foot
stomp the gas pedal very fast
climbs to 5000rpms hold it for 1-2 seconds at most.
let off the brakes and car doesnt move it just revs to redline.
I have search and found you need to adjust the torque tables.
but in the sst stuff there are a bunch of torque tables which ones do i adjust and how?
Sometimes it works and other times it does not work.
thanks for helping.
Old May 17, 2021 | 06:51 AM
Llew's Avatar
I've got this same problem now. Launch Control use to work everytime. Car was bone stock (factory tune) ran a 13.7 1/4 mile.
I put drop in HKS hybrid panel filter (still factory tune) car launched perfectly ran 13.5 1/4 mile.
I put MAP Upper intercooler pipe from turbo to top of engine. Car ran a 13.4 but not launch control will only work with the traction control left on. If I hold down the ASC button the car just revs to red line and slow down message pops up.
I recently put a 3 inch Cat Back exhaust and now the car would not launch at all not even with traction control left on.
How do I fix this?
Old May 18, 2021 | 10:22 PM
jrsimon27's Avatar
How do I fix this?
I told my tuner to add spark cut have only tried it once and it works great. But reading a lot regarding spark cut it seems its harder on engine and clutches the thing is that with it i launches lower rpms 4600rpms and i dont get the slow down message as i did with the oem launch control.
Old Dec 28, 2021 | 10:59 AM
hibby's Avatar
How do I fix this?
Is the car tuned for your modifications?
logic
Oct 22, 2014 07:29 PM
Evogelion
Northwest Region
12
Dec 5, 2006 04:35 PM
initialDRacer
Mid-Atlantic Region
Apr 22, 2005 05:13 PM
