EcuFlash SST tables...
Since I keep getting a ton of PM's about this.....
The SST tables are still being tested. SST Torque limit 1-3 Clutch A Engage/disengage Clutch B Engage/disengage and a couple others. Good news is I (and some others) have been getting very good results now that we have access to these tables. I've had a couple MR's with decent power open the clutches on our mustang dyno after repeated pulls (and some even the first pull or so). After some SST table tweaks, no more issues. Also shifts have been tweaked to be more aggressive, etc. There is also a table that limits lower ignition timing on the MR. Meaning, the ECU will not run under a certain degree, even if you have lower in the main ignition table. You can imagine this can cause a problem on larger turbos, on lower octane like 91. Now that is no longer an issue. You find this here: https://www.evolutionm.net/forums/ev...wer-bound.html Still looking into some other MR tables. - Bryan |
Awesome! keep us posted!
Originally Posted by GST Motorsports
(Post 7779395)
The SST tables are still being tested. SST Torque limit 1-3 Clutch A Engage/disengage Clutch B Engage/disengage and a couple others. Good news is I (and some others) have been getting very good results now that we have access to these tables. I've had a couple MR's with decent power open the clutches on our mustang dyno after repeated pulls (and some even the first pull or so). After some SST table tweaks, no more issues. Also shifts have been tweaked to be more aggressive, etc. There is also a table that limits lower ignition timing on the MR. Meaning, the ECU will not run under a certain degree, even if you have lower in the main ignition table. You can imagine this can cause a problem on larger turbos, on lower octane like 91. Now that is no longer an issue. Still looking into some other MR tables. - Bryan These tables need more testing before released to the general population please allow us to know what when and why they work before we let people loose on their trannys As we know more im sure you all will know! |
(Post 7779395)
This is coming along nicely! keep up the good work :)
That's great to hear Bryan! {thumbup}:beer:
Does this also mean that changing the SST tables is possible on the Ralliart as well? |
Originally Posted by Psycho09RA
(Post 7779922)
Does this also mean that changing the SST tables is possible on the Ralliart as well? and the 2009 / 2010 MR too {thumbup} |
Originally Posted by HB Speed
(Post 7779927)
ive already got the 2009 and 2010 RA tables ready
and the 2009 / 2010 MR too {thumbup} Sweet!:headbang: |
DEFINITELY good news. {thumbup}
(Post 7779997)
Sweet!:headbang:
we tuned a RA with ETS35r and were working with these to make it handle it !! |
Originally Posted by lodifreefly
(Post 7779814)
Does this mean you found the shift ign retard table and it wasn't the warm up ign retard?
Warmup retard is warmup timing .. very little is understood because these tables get sent to an address that I can't log .. for now .. so I don't know what it does after that .. There's a few guys just running these on beta maps that I sent out .. just to make sure there's no weird glitches happening .. |
Originally Posted by gunzo
(Post 7791546)
shift retard is a function of one of the tables bryan mentioned .. there is no direct table that determines shift retard timing ..
Warmup retard is warmup timing .. very little is understood because these tables get sent to an address that I can't log .. for now .. so I don't know what it does after that .. There's a few guys just running these on beta maps that I sent out .. just to make sure there's no weird glitches happening .. "Ignition Warmup Retard This table is used on warmup and also used on the MR SST model for shift ignition retard" |
Are these the same as the Ignition Ceiling and Ignition Floor tables in Cobbs Access Tuner software or is this something in addition to that?
Any updates on the SST tables?
Good news! Thank you for your hard work (GST, HB ,Gunzo and others)!
