Wiring Harness P# request
Old Oct 10, 2011 | 04:20 PM
enragedpanda's Avatar
Exclamation Wiring Harness P# request
im needing to get a new brake light harness mine is shorted out and eating fuses right now, can't find the short. would love to get a part number for the harness
Old Oct 11, 2011 | 07:36 AM
RussellM's Avatar
Plat Vendor
This is just a short pigtail that the bulb actually goes into.
Please Follow the Link Below
http://www.mitsubishiparts.net/cart/?id=571&pn=mn169707
Old Oct 11, 2011 | 10:29 AM
Hmmm so the dont have the full harness from the brake switch back ect...
Old Oct 11, 2011 | 10:42 AM
RussellM's Avatar
Plat Vendor
I guess it all depends on where your short is and what harness you actually want/need. This is for the 3rd Brake Light - I guess you didnt say that. Im not sure what I was thinking there.
So what harness do you need...specifically?
Old Oct 11, 2011 | 10:47 AM
Im not exactly sure what harness it is atm havent had the time to pull it apart yet. But so far ive replaced bulbs, brake switch, light assembly and fuses. All I can say is my right light is way brighter then left when it does work. I even put higher amp fuses in to see if they would blow same thing. Idk how many harnesses their are but im guess ima need brake swith back and start from there.
Old Oct 11, 2011 | 11:12 AM
RussellM's Avatar
Plat Vendor
Have you double checked to see if you are running the correct bulb? It sounds like it may be pulling too much power and causing your fuse to blow.
Old Oct 11, 2011 | 02:57 PM
ill replace the bulbs once more and or pull them and see if they are right may have picked up the wrong bulb. sorry i do eletrical at work all the time easy to over think things. if its not the bulbs i'll go throu and check all the grounds and see if a wire is frayed or grounded out somewhere it isn't suppose to.
Old Oct 13, 2011 | 02:57 PM
Well when I disconnect all the brake lamps the fuse blows, I did a continity check on the brake switch its still good. Which leads me to.believe the wiring is bad from switch to the lamps
mrbonilla
Dec 11, 2016 06:04 PM
mrbonilla
Nov 17, 2016 05:42 PM
Igaly1021
Jun 21, 2016 03:59 AM
JSC Speed
Evo 'For Sale' Exterior Styling
58
Oct 28, 2008 07:57 AM
ilive2win
Aug 5, 2008 06:40 AM
