Evo 8 Water Inlet - Mitsubishi (MN143306)
Old Apr 25, 2023 | 02:14 PM
vtec fever's Avatar
Hello as many of you know the evo 8 water inlet pipe that connects to the water pump at the back of the engine block is discontinued (MN143306). Mine is getting rusty. Is there another Mitsubishi inlet pipe that a direct fit, if not what are you evo 8 dudes doing to bypass this issue or what have you all done to fix this, I can’t be the only person that has com up on this problem. I have searched and I see replacement pipes for the evo 7 and 9 but from my searching all I have reading is that they are not interchangeable with the evo 8.
Any info or solution to this problem will be appreciated.
Old Apr 26, 2023 | 09:30 AM
Kevin.'s Avatar
https://buschursllc.com/br-cart/home...ter-pipes.html
vtec fever
Apr 28, 2023 01:37 PM
legacydestroyer
Mar 2, 2018 12:40 PM
sumopower87
Dec 15, 2014 10:56 AM
Boostedx11
Jun 6, 2011 09:08 PM
