Good tire gone bad...
Old Oct 31, 2004 | 05:21 AM
RoundPro's Avatar
It happened around 110mph on a straight at MSR...
Attached Thumbnails Good tire gone bad...-img_0138.jpg   Good tire gone bad...-img_0129.jpg   Good tire gone bad...-img_0132.jpg
Old Oct 31, 2004 | 05:31 AM
chrisw's Avatar
What kind of tires?
Old Oct 31, 2004 | 06:20 AM
RoundPro's Avatar
Pirelli slicks.
Old Oct 31, 2004 | 06:26 AM
RoundPro's Avatar
A larger pic... Even at this kind of speed, the care is very easy to control... This my third blow out in the last year or so.
Old Oct 31, 2004 | 06:39 AM
RoundPro's Avatar
HAving trouble uploading big pics. Sorry.
Old Oct 31, 2004 | 06:48 PM
metaphysical's Avatar
Registered User
Did you blow it through a cording spot?
Old Oct 31, 2004 | 07:14 PM
RoundPro's Avatar
No... I think I was a little low on tire pressure. Our guess is that the excess heat built up on the edge of the tire caused it to pretty much explode ( I was porbably running 10psi or so lower than where I should have been).
Old Nov 1, 2004 | 04:34 AM
rsr14's Avatar
What pressure? The correct pressure should be around 31 hot. Did you buy these used or was this a new set? If new, how much time was on them?
Old Nov 1, 2004 | 06:27 AM
RoundPro's Avatar
I was at 29 in the front and 31 in the rear.... hot.
Tires were used but only heat cycled once.
Also was running 2.7neg camber and 1/16 tow out witch feels great on the car except on corner exit... Need a front LSD really bad.
Old Nov 1, 2004 | 06:39 AM
JTB's Avatar
JTB
This might be of interest.
http://www.roadraceengineering.com/evoquaifegb.htm
Old Nov 1, 2004 | 06:55 AM
RoundPro's Avatar
Originally Posted by JTB
Yap, I know Thanks.
Old Nov 6, 2004 | 10:40 AM
CincyEvo's Avatar
At a track day, I had a Hoosier develop a huge ballooon, about 1/2 way around the surface of the tire. It came through the tread where it was apparently corded and stuck out about 3/4" and about 3" wide. Fortunately it didn't blow and I was able to get back to the pits.
Old Nov 6, 2004 | 01:51 PM
plokivos's Avatar
did you damage your front lip? it looks all fall apart.
