Motion Ratio?
Old Mar 5, 2019 | 07:48 AM
Dallas J's Avatar
Veteran: Army
I really dont understand why Ohlin cant accept they are wrong in something as simple as this. And its not like its a new thing, its been 10 years or more and the MR takes like less than an hour to measure.
They also screwed up pretty bad on the Ohlin flags with their canister locating pin breaking on nearly EVERYONES sets. The guys I talk to that don't know about the pin issue usually check and don't have one anymore. And then others Ive talked to tell me of the broken canisters they've had to have repaired. It was an easy enough fix with a little bit of thinking but they just aren't interested in going back and revising their parts unless it means cost reducing them (see current R&Ts vs the previous DFVs).
Old Mar 5, 2019 | 10:15 AM
kyoo's Avatar
old platform, no need to develop anymore. 8/10 is what i run on my dfvs
Old Mar 9, 2019 | 09:35 AM
EVOFans's Avatar
What is the difference between current R&T vs DFV?
I thought R&T = DFV?
Old May 2, 2019 | 07:39 AM
kyoo's Avatar
do the motion ratios impact actual ride from the springs as well? i.e., if it's 10k in the back with 0.6 MR, does it "feel" like a 6k spring, or just behave like a 6k spring but ride like a 10k spring?
Old May 2, 2019 | 07:55 AM
Dallas J's Avatar
Veteran: Army
It rides as what the wheel rate its, which includes the motion ratio.
Old May 2, 2019 | 10:26 AM
Pal215's Avatar
They are the same. The DFV (Dual Flow Valve) is a product feature on the Ohlins R&T, which are coilovers built for Road & Track.
Old May 2, 2019 | 10:36 AM
Dallas J's Avatar
Veteran: Army
They arent the same exactly when it comes to modifying them. The original DFV bearing housings are different both front and rear from the current R&T. For most it wont matter but does effect things when trying to install my rear coaxial spring perch.
Old May 2, 2019 | 11:36 AM
heel2toe's Avatar
Dallas- did you ever make a lil how to doc on how those rear perch things go together? I know I asked you like a year ago when I picked em up but looks like I'll be playing with my suspension in the next few weeks .
Old May 2, 2019 | 12:39 PM
Dallas J's Avatar
Veteran: Army
I thought you guys sorted it out? It was basically you use just the perch and the factory spacers instead of the spacers I sent. Make sure you have full articulation of the hat and its good.
Old May 2, 2019 | 12:45 PM
heel2toe's Avatar
Lol, naw I've got front and rear plates from you and springs all around that I need to swap over, just haven't got around to it. But if its self explanatory then all good I'll learn to fish
Old May 2, 2019 | 05:06 PM
Ayoustin's Avatar
If you have the new style and get hung up let me know. @V.8MR and I did his last year. I don't remember the exact order of spacers etc. on the rear but we can always grab photos for you.
Old May 3, 2019 | 07:09 PM
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
Originally Posted by Nicolas
I recently bought a set of Ohlins DFV and contacted the company to make sure that the spring go in the order of 8/10 as i read in the forum. However their response was much differentthan what i expected.
Hello,And thanks for your message.We recommend the 100N in the front and 80N in the rear.The Motion Ratio of the Car is nearly the same front and rear.You have more weight in the Front so to have a solid balancedBase I would go this way.I guess that some people change the Springs to change the Balance to oversteering.Because it´s an 4x4 with some weight in the front axle. This cars are normallymore in the understeering way.
So my question is, what is the motion ratio front and rear. Do most users install it in the "wrong" way? Is the company (Ohlins) ignorant in regards to the product it sells? Is it something different?. I am really confused.
Did Ohlins write that or one of their resellers?
Could be a little bit of liability-avoidance in the response, too.
Old May 6, 2019 | 09:56 PM
V.8MR's Avatar
I can get some pics for posterity tomorrow when I get back in the garage.
Old May 7, 2019 | 03:46 PM
Nicolas's Avatar
Directly from Ohlins. Sweden.
https://www.ohlins.com/contact/contact-us/
Old May 8, 2019 | 08:08 AM
heel2toe's Avatar
Thanks bud if you have pics handy post em up! Might throw car up in the air this weekend and overhaul suspension but TBD if I do that or cross off one of the other million things on my list.
