Best Wheel for ESP
Old Jan 26, 2005 | 07:20 PM
feldguy's Avatar
go to joe250.com and that'll tell you whats involved in putting 285's on
Old Jan 26, 2005 | 07:36 PM
chronohunter's Avatar
Originally Posted by 93esp
The lsd coupling will definitely know if the tire diameters are different. Different diameters will result in slip across the coupling and definitely toast it. Running larger diameter tires on the rear is a common 4wd truck trick but they don't run a center differential.
I am a big believer in the wider front tire setup (as my co-driver would attest...) and spent two days in Peru, IN testing the wider front tire back to back with an equal width setup. I changed the suspension settings (spring rates, swaybars, alignment, tire pressures, etc.) to try to make the wider front setup happy and finally concluded that the difference in grip was making the center viscous coupling unhappy.
Eric
Eric I would agree if the diameter is too different. The front and rear wheel speeds are always different whenever you are turning, it's not like a little slip is going to hurt it (that is what it's there for). The trick is finding out how much it will tolerate before it adversely effects handling and/or longevity.
It sounds like during you testing that the handling gets squirrelly before you hurt the diff (?). So...there may be room to play.
Time attack JDM guys commonly run narrower rear rims to remove some rear grip and they have been doing it back before the EVO 4/5 days which had a viscous centers like ours. The narrow rim crowns the tire which makes it a little taller (and the contact patch a little smaller).
Can you tell us more particulars about you test? Were there any corner types where you felt it worked and where was it didn't etc. Turn-in, mid-corner, exit and in slow, medium and fast corners. Come on, spill it. It sound like you really tried to make it work
Thanks
Old Jan 26, 2005 | 07:49 PM
kevo's Avatar
One thing I found interesting is the JDM time attack evos don't run any tires wider than 255 even they have huge fender flairs or widebody kits. Example, the two fastest car on Tsukuba, HKS Evo with 40mm widebody and HRS CyberEVO with 25mm front fender flairs. They can easily fit 285 or even larger tires on but choose not to. I wonder what's the reason behind it since mods are unlimited.
Old Jan 27, 2005 | 05:18 AM
93esp's Avatar
Originally Posted by markdaddio
Eric, What brand of tire, and what was the differnce in tire diameter. With Hoosiers, a 275/35/18, and a 245/40/18, are within a tenth of an inch in diameter. The diff should not even notice that I would think. By coincidence it is the rear tire that would have a slightly bigger diameter. It seems as though the 17's are not available in the autocross compound to do this with 17's. What do you think.
Thanks,
Mark
I ran 285/30-18's on the front and 245/40-17's on the rear. I tried Kumho Ecsta V700 (got them for free...) and Hoosier A3S04's. The Kumhos were exactly the same circumference and the Hoosiers were a little smaller in the rear if I remember correctly.
The differential issues were not related to tire diameter it was relative grip level. On the throttle the car would tend to spin the rear tires immediately and the coupling would lockup to try to keep the axle slip to a minimum. It's hard to describe the effect unless you've ridden in the car - very violent inside and definitely only happened with different width tires on one axle. I did run the wider tires on the rear once and the effect was no better. With the active center differential the locking effect may be more progressive and have a better chance of working.
Eric
Old Jan 28, 2005 | 01:15 PM
markdaddio's Avatar
Eric,
Thanks for the input. I am still not sure whether or not the monster tires are needed. I read somewhere that with the big tires you guys were getting up on two wheels. lol. I guess I have some experimenting to do.
Mark
Old Feb 5, 2005 | 05:32 AM
ESPCamaro's Avatar
Obviosly by the user name I can't offer much...
I can say that I've never noticed Erics car on two wheels. I do remember seeing the stock EVO's on two wheels at the DC Tour last year (in pictures-I didn't go)
I'm not sure what you guys consider cheap for wheels but I'll offer my experiences. For us (4th gen f-body) reproduction Grand Sport Vette wheels are available and there are TONS available so they are dirt cheap. But they also weigh TONS.
Last year I bought two Fikse wheels that were basically brand new and for a song...But the cost of two more new wheels, would be just barely less than what John at CCW was willing to sell....
In the end, I paid $1,895 shipped to my door-FL to MI, for a set of 2 17x11's, and 2 17x12's.
Old Feb 5, 2005 | 05:39 AM
ESPCamaro's Avatar
One other question. This maybe the best place to ask since very few or no pony cars have experimented with 18" wheels.
Last summer I heard some folks grumbling that the 18x10's they bought were a waste, since the 275's were faster than the 285's. And this was directly related to the sidewall height. Where a shorter overall tire, on a lighter 17" wheel, would accomplish the same thing.
Tunnel, on both the M3 and 330, and I heard the same thing about Butts' IS300. Note this was a Hoosier tire issue so mayb that was the cause....
So are you guys running the really short sidewall because you get the extra width with a shorter overall height? So you also beleive it to be faster than a taller sidewall, yet narrower width.
Given the choice would you, run a shorter sidewall in front, or taller, given the same tread width....
I would like to try a 18x11 front with a 315-18 tire, but wonder why no one else has. And at $900 for wheels, and close to$500 for tires, it'll be quite the expensive test.
Old Feb 5, 2005 | 10:21 AM
93esp's Avatar
My car was routinely up on two wheels with the large tires. I have several pictures with daylight between the inside tires in sweepers as well as some corner worker comments from slaloms.
Eric
Old Feb 5, 2005 | 10:25 AM
93esp's Avatar
I did a test at Peru with the 275 and 285 Hoosiers and the 285's were consistently faster. The smaller tire definitely helps the gearing which is a consideration with a torqueless 4 cylinder....
Eric
Old Feb 6, 2005 | 11:40 AM
ESPCamaro's Avatar
Eric what kind of differences in responsiveness did you notice between the 275 and 285's. I'm understanding correct that the 275 is actually a taller sidewall tire right?
So was the 285 faster because of absolute grip, or more a measure of the responsiveness due to the shorter, stiffer sidewall.
Old Feb 7, 2005 | 05:42 PM
93esp's Avatar
There really was no comparison between the two tires - the 285 definitely had better overall grip. The car pulled out of the corners harder with the 285's as well. The 275 does have a taller sidewall and just felt like it was constantly sliding around in the corners compared to the 285. I don't remember much about the responsiveness.
athayes20
28
May 22, 2012 12:13 PM
nexgen
May 28, 2010 05:58 AM
93esp
For Sale - Wheels / Tires
Sep 21, 2006 08:14 PM
v8k1ller
Nov 8, 2005 05:28 PM
Joe250
Sep 22, 2004 12:55 PM
