sway bar link or camber plates
Old Jun 17, 2005 | 04:08 PM
bdking57's Avatar
I currently have my car set up with a croxx plate, sparco bar, hotchks rear sway bar, Ti rear strut bar, hotchks springs. Last week I attended my first autox and was getting good by the end of the day. The car feels pretty neutral but i feel I need more oversteer for tight turns. Me and the other evo on the track were both getting tore up on a 180 degree turn after a long straight. Which would be the best $ for $ addition. I was comtemplating between the perrin sway bar links for $110 or ground control camber plates for $300. How much does a camber plate install cost.
I am running hankook rs2 that did great.. and i cannot believe their 245/45 size didnt result in some sort of rubbing issue.. but no major rubbing occured. I feel like i definately had potential for more grip.
FYI..I plan on a nice set of coilovers after my stock struts are shot.
Old Jun 17, 2005 | 07:50 PM
992gnt's Avatar
Try tire pressure adjustments first. I can take my car from horrible understeer to cone-smashing oversteer with just pressure adjustments. Air is cheap.
Old Jun 17, 2005 | 09:13 PM
bdking57's Avatar
the front tire was perfect. We used some white shoe polish as an indicator.. i noticed the rear tires were over inflated however.. I had all four tires equal.
Old Jun 17, 2005 | 09:20 PM
Compjoc's Avatar
What do swaybar end links do for you?
Old Jun 18, 2005 | 07:08 AM
bdking57's Avatar
according the the manufacturer.. the stock sway bar links are very tiny and compress under full load. This prevents the sway bar from doing its job 100%. You can see while your under there that the links are pretty tiny.. why does having a super thick sway bar set to the stiffest setting help with dink links attached to it? I guess thats what they are saying.. looking for someone who can verify this as a good investment or not.
Old Jun 18, 2005 | 08:44 PM
russjnco's Avatar
you will notice that the sway bar is more effective when you get the endlinks, the stock ones are horrible. I would go with the endlinks first and bump up your rear tire pressures over your fronts. I'm running 2 psi higher in the rear with my perrin sway bar set in the middle position. The car feels fairly neutral and I'm running the hotchkis springs as well.
Old Jun 18, 2005 | 10:01 PM
bdking57's Avatar
great so you felt a pretty good improvement.. seems like the sway bar would up correctly up untill the point when the sway bar links could become overloaded. MY rears tires definately needed less psi.. they were over inflated.. i could see by marking them with chalk that i was not putting all the rubber to the pavement.
Old Jun 20, 2005 | 11:23 AM
JasonS's Avatar
I've got a set of Ground control camber plates that I'm not using if you want to buy them....$225.
They're new, not ever installed on car.
PM me if you're interested.
