evo8 hub adapters
I really hope that adapter has splines that fit the rod splines and it's not just press fit on there.
I don't even want to know what will happen when you bang a track berm.
nils, do you think this adapter could work with the stock wheel? I'm guessing the "bolts" on the stock momo wheel are only cosmetic, but could they be drilled and replaced with real ones to match up with the ring pattern on the adapter?
There's important bits behind those fake "bolts" like the airbag module and the clock spring assembly, so drilling would be a bad idea.
Originally Posted by nubby
I'm assuming that if you want to keep the stock wheel, you also want to keep the airbag.
I agree, seems like keeping stock wheel with new adapter would be a pain to do, even if you removed the airbag. Anything is possible though
n
Originally Posted by trinydex
if you want antoher hub assembly that is sure to work contact aspec about their works bell units. they're ball bearing types and can be fitted with qds
no hub will work with the stock wheel... but why would you want to? quick disconnect? cuz if you're gonna qd it then you are sacking hte air bag anyway. i'm confused.
- trying to get a better driving position by moving the steering wheel closer to me, but I like the stock one + airbag better than after market.
Just confirmed that the MOMO PN 6116 will not work on the 03 EVO.
Where we come splash
Nils did the splash allow you to keep the rolling pin connector to allow you to keep your turn signal cancelation?
Ben
Ben
