5pt harness with stock seats
Ok, this might sound like a dumb question, but is it possible to cut the lower seat cushion for a 5pt harness or is there bracing in the way to run the belt? I have a harness bar and 4 of the 5 points right now (just for autocross) and want to add the 5th point. I drive the car on the street daily and want to use the stock seat belts so a race seat doesn't really work well (since the stock belt won't work). Anybody do this yet?
Construct a bar that goes between the front two floor seat bolts. Put a loop or a bracket of some kind in the center of the bar and bolt the submarine belt to the bar.
https://www.evolutionm.net/forums/sh...d.php?t=179674
And you could attach both the 5-point lap belt and the stock receiver to the same tab, if you wanted to run both.
Originally Posted by nubby
I run stock belts with a race shell, you just use the stock seat belt receiver that mounts to a tab on the seat base, here's a thread with some info:
I didn't cut my seat. That would be silly. I just ran it around the front of the seat. Its only there to hold the 4 point down.
Jon
Originally Posted by kekek
so Warm Pepsi, what was your final seat/rail/harness/bar setup?
with simpson harnesses and an autopower roll bar.
Originally Posted by WarmPepsi
https://www.evolutionm.net/forums/sh...d.php?t=174613
Did you happen to weight the autopower rollbar? Did you mount the substrap with a welded backup plate in the floor?
I was looking into harnesses with the same situation you have. I saw that Shroth makes a 6 point where the 2 sub belts bolt to the 2 stock front bolt on the seat mount/floor. all the other mount points are the same as other harnesses, stock side mounts and harness bar or C&D rear seat bolts.
Nice! I thought about those seats, but I really wanted to sit in something before I purchased. Loving my Pro2000.
I didn't weld in the substrap, but instead made a mounting setup (bolt through with solid steel plates/bushings)
ie: it's not going anywhere, i sandwiched the floor in multiple spots and used a grade 8 bolt as a stud for the strap.
RA11226
Evo X How Tos / Installations
120
Jun 24, 2022 03:19 AM
