Track cars = windshield crack?
Old May 4, 2006 | 10:05 PM
Kayaalp's Avatar
Originally Posted by jemjow
i had mine replaced 2 days ago, around here in Queens. THey dont have the evos winshield in stock, so i just went for the lancer's windshield. I believe theyre just the same. Different part number though. But it fits well on mine. $150, not original mitsu. BUt what the heck, it will get chipped again anyway.
The stock Lancer windshield is a tiny bit thicker and heavier than the one on the Evo. Should be more durable. If it fits, then
Emre
Old Jul 30, 2006 | 06:51 PM
WarmPepsi's Avatar
i'd like to bring this back up for debate with this video.
http://www.warmpepsi.com/vids/Homestead_Crack.avi
The beginning shows clearly no crack, and i edited out the middle of the lap just for time and file size, i'm nowhere near any other cars.
Old Jul 31, 2006 | 04:40 AM
kingkyle's Avatar
Since I posted this thread my crack is now 20 inches long and there is a 2nd crack that is also 20 inches long.. both in the same direction and coming from the same place. Track crack = true
not sure if its similar chassis setups... but 20+ track events per year will do it.
Old Jul 31, 2006 | 05:01 AM
WarmPepsi's Avatar
i'll be getting it replaced, as i have no urge to show up to track, and fail tech, because of this.
Old Jul 31, 2006 | 05:21 AM
kingkyle's Avatar
Well... the good news is the SCCA / EMRA / PDA all dont care how cracked your shield is. They say as long as it doesnt hurt your vision.
-Kyle
Old Jul 31, 2006 | 05:28 AM
WarmPepsi's Avatar
-Kyle
interesting. I really didn't want to ask yesterday, for fear of being turned away for the later sessions, but i had other mechanical/electrical issues (anti-lock light came on, plenty of fluid, and unless i went through a set of pf97's in a day, i still had plenty of brakes, just no anti-lock.)
...the the acd went nuts and lit up like a christmas tree. good times. glad i trailer the car.
Old Jul 31, 2006 | 12:15 PM
RazorLab's Avatar
Check your ABS sensors at the hub and also the lines. You might have melted them. You recently put new coilovers and tires on right? Did you take your brake dust shields off? The ACD gets inputs from the ABS and speed sensors so messing up a ABS sensor might have had a domino effect.
Old Jul 31, 2006 | 12:30 PM
WarmPepsi's Avatar
thats exactly what i've thought.
However, i ran ok on sat, and it happened on sunday, when i really wasn't running as hard.
But tonight i'll see when i pull the wheels, swap brakes, etc.
This is the first time i've run without an undertray, and i noticed my coolant temps were up about 10 degrees, but it's also the dead middle of summer. But the oil temp was down.
Old Aug 1, 2006 | 12:37 PM
byron3636's Avatar
i haven't tracked my car yet, but i have a big crack on my lower right.
Old Aug 11, 2006 | 09:02 AM
Steve_P's Avatar
I didn't get any video from the link, only audio. Anyway, you should be able to tell a rock vs stress crack. A stress crack starts from the edge and not from a rock chip or bullseye which will not be on the edge. If it starts from under the WS wiper valence, then it obviously wasn't a rock that caused it. Stress cracks in a windshield are real esp in unibody cars with the urethane adheisive they use today.
One thing that determines how easy a WS it will stress crack, besides the body stiffness, is how the WS was made at the WS factory. This does not have anything to do with the 'raw' glass, the sheet itself, but after it is cut/bent to make the WS. If made "right", there will be a compressive stress around the outside of the glass which makes it stronger than if it's not there; it is almost like a minor tempering effect. I worked in an auto glass factory and dealt with issues like these and researching the whys and the variables.
Old Aug 11, 2006 | 02:06 PM
WarmPepsi's Avatar
The video was divx, i can't seem to get any video in it, whne viewed in quicktime, but WM player is what i normally use.
Crack comes down from the top, right above the rear view mirror, and now comes down 1/3 of the windshield. My true thought is that maybe the KW's i have, were set too soft for homestead, and i was possibly bottoming out on the drivers front corner, and after so many times, it just gave way.
I honestly didn't feel like i was ever bottoming, but i can't 100% say for sure i didn't.
Old Sep 13, 2006 | 11:09 AM
Loser's Avatar
Was at Pocono South three weeks ago and I developed a crack that started from the top corner of the passenger side. End of the day it was almost 13-14 inches long. I don't recall any stones getting kicked up that day as it was a wet event, and there's no sign of a rock chip at all. I suspect it's a "track crack" due to the banking left on the oval on which we were averaging 100-110mph.
-Kyle
They aren't concerned about it breaking?
Old Sep 13, 2006 | 11:43 AM
kingkyle's Avatar
Well... the only concern is visibility. Todays modern windshields wont just shatter and throw glass everywhere. they are made so they will crack all day long and never shatter. Ask some guys out west (colorado), Paul Gerrards evo has about 6 cracks going across the whole windshield and back.
I'm starting to believe my own track-crack theory even more now...
Old Sep 13, 2006 | 12:19 PM
meanmud's Avatar
Hmmm....Track Crack - I've smelled it before
Old Sep 13, 2006 | 01:01 PM
kingkyle's Avatar
Hah....
