Alignment spec
Old Jun 13, 2006 | 04:58 PM
S1monLM's Avatar
Alignment spec
Post your setup here
Camber, toe, caster, heights, corner weight result.
Old Jun 14, 2006 | 05:22 AM
mayhem's Avatar
F: -3 camber, 0 toe
R: -2 camber, 0.15 toe (just a hair)
Old Jun 14, 2006 | 05:39 AM
scorke's Avatar
F:-2.75, 0 toe
R:-1.5. 0 toe
Corner weighted witihin .02 percent diagonally(people reading this thread should understand what this means...) Car is very very very quick to turn in, and has a touch of on power over steer, the lack of the LSD still results in some understeer on corner exit if you get on it too early, car is very very easy to rotate mid corner however.
Scorke
Old Jun 14, 2006 | 05:51 AM
992gnt's Avatar
F: -2.5, 0 toe
R: -.8, 0 toe
I can't remember the corner weight numbers, but we spent about 3 hours getting them dialed in. The car handles very much like described above. Loads and loads of grip, but very easy to rotate if desired.
Last edited by 992gnt; Jun 14, 2006 at 01:13 PM. Reason: Fixed front camber setting
Old Jun 14, 2006 | 07:15 AM
kingkyle's Avatar
F: -3.8, 0 toe
R: -1.8, 0 toe
Old Jun 14, 2006 | 12:41 PM
tweekscratch's Avatar
Autocross only:
F: -3.4, 0 Toe 25"
R: -1.8, 0 Toe 25.5"
The car was just tuned to this and I haven't been on course yet. Based on the slip I had on my way to work today though I think I have the push finally dialed out of my car.
Old Jun 14, 2006 | 01:07 PM
RazorLab's Avatar
-2.7
-1.4
zero toe.
Old Jun 21, 2006 | 08:29 PM
Dropspeed's Avatar
Front Camber -3.5, Toe 1/8" out , 6K front (changing to 10K)
Rear Camber -1.4, Toe 0, 8K rear (changin to 14K)
Corner weighted, Cross weight 50/50 with driver, 61/39 front/rear split
Why all of the 0 toe front cars above????? Please post your spring rates also
Mattj
Old Jun 22, 2006 | 12:01 PM
johannes's Avatar
I would really appreciate some approximate ride heights front and rear as well-thanks!
Johannes
Old Jun 22, 2006 | 12:07 PM
jid2's Avatar
Mattj
Word!
I'm running 1/8" toe out in front also.
Front Camber: -3
Front Toe: 1/8" out
Rear Camber: -1.5
Rear Toe: 0
Old Jun 23, 2006 | 11:14 AM
'ringmeister's Avatar
camber f/r: -2.5/1.9
toe f/r: 1/16 out/0
spring rate f/r: 400/475
cusco rear bar
quaiffe
at work, can't remember the ride heights
Old Jun 24, 2006 | 02:25 PM
Loser's Avatar
Just got my car aligned. They managed to max out the rear camber at -1.9, but only managed -0.8 in the front. The technician was adjusting the upper of the two bolts at the bottom of the strut. Is there another bolt to adjust the camber?
Front:
Camber -0.8 degrees
Toe 0
Rear:
Camber -1.9 degrees
Toe 0.05 inches
Old Jul 20, 2007 | 01:15 PM
4cdndctn's Avatar
Darn thread died...
front:
camber: -2.3
toe: -1/16 toe out
rear:
camber: -1.0
toe: 1/16 toe in
Will be adusting for more camber both froent and rear next time around
Old Jul 20, 2007 | 02:40 PM
texrex2002's Avatar
front: -2 camber, tiny bit of toe in (like .04/side), 8kg springs
rear: -1.4 camber, tiny bit of toe in (like .07/side), 10kg springs
