"Track" alignment specs for stock MR suspension?
Old Jun 21, 2006 | 10:40 AM
Tsurara's Avatar
I currently run in stock classes and still have the stock MR struts/springs, but I need to dial in some more negative camber for my r-compounds. I was going to do a max negative camber with zero toe, does anyone have the exact specs? Is there a better option for me?
The shop I am bringing it to has the factory recommended settings, should I be going outside their max/min at all?
If it matters, its stock MR suspension with 17x9 Gram Lights and 255/40/17 Toyo RA1s
Thanks.
Old Jun 21, 2006 | 10:50 AM
scorke's Avatar
On stock suspension ots going to be hard to get a lot of negative camber ask for as close to -2 as possible in front -1 or so in the rear then a little bit of toe out if your going to be autcrossing it.
Scorke
Old Jun 21, 2006 | 10:54 AM
thatsMR2u's Avatar
yaah u can shoot for -1.8 camber with 0 toe for the front and -1 with .12 toe for the rear
Old Jun 21, 2006 | 10:55 AM
fromWRXtoEVO's Avatar
Tsurara,
Contact Works Racing, they focus a lot on suspension of set up.
Carlos
Old Jun 21, 2006 | 10:59 AM
Tsurara's Avatar
Cool, thanks guys This is road course only... no autocross at all.
Old Jun 21, 2006 | 11:02 AM
scorke's Avatar
Lime Rock? , go july 3rd/4th I'll be there... Where abouts in MA is dentsport?
Scorke
Old Jun 21, 2006 | 11:04 AM
Tsurara's Avatar
Scorke
Gonna be at NHIS competing July 3rd 4th otherwise id be there I need to get out to LRP this year...
Dentsport is in Norwood, MA, really good guys. They have a shop Evo II!
thatsMR2u's Avatar
Scorke
Norwood, MA
02062
... so near boston
Old Jun 21, 2006 | 11:06 AM
Tsurara's Avatar
Originally Posted by thatsMR2u
Norwood, MA
02062
... so near boston
Not quite... more near the RI border, its about 45 mins away from Boston.
Old Jun 21, 2006 | 11:10 AM
Kidloco51's Avatar
Just got my car aligned on monday. 06 MR stock suspension with exception of camber plates and swift springs.
I am running
Front -2.5 camber
Rear -1.5 camber
Front 0* toe
Rear just a hair of toe in.
If you are running any r compound at least -2 degrees on the low side.
Old Aug 3, 2006 | 12:51 PM
vanisher's Avatar
I too am trying to get my MR suspension aligned for track...
I wish someone knew of some places in Illinois.
Old Aug 3, 2006 | 12:58 PM
nukblazi's Avatar
There was just a thread on this with a couple tips.
I've also heard of flipping the carriers bolts to get more, close to -3.
