Track whores with MRs?
Old Jan 14, 2009 | 04:46 PM
  #796
Oil Doc's Avatar
Originally Posted by andrewzaragoza
is there a shop that makes a tranny cooler kit for the 6 speed?
Use AMSOIL MTG and there should be no need for a cooler.
Doc
Old Jan 14, 2009 | 05:21 PM
  #797
mrfred's Avatar
Doc
I'd wouldn't bet on that. MTG may be able to withstand higher temps, but there is also the issue of gear strength versus temperature.
Old Jan 14, 2009 | 05:29 PM
  #798
marksae's Avatar
Yeah, using a different oil is not going to change the load carrying capacity of the actual gear.
Old Jan 14, 2009 | 05:48 PM
  #799
Oil Doc's Avatar
Not true.... A high quality synthetic will run cooler to start with and the AMSOIL MTG has a Superior Film Strength compared to other lubes.
I have been able to run the AMSOIL SVG 75W-90 in an application specifying a 75W-140. This particular application has problems shearing the teeth off of the Ring and Pinion. 345,000 miles later under severe use,.... Overweight and heavy towing to over twice the recommended limits, no problems using the 75W-90.
Unless this thing is out on the track for hours at one time without cool down time, there should be no reason for a cooler.
Doc
Old Jan 15, 2009 | 07:27 AM
  #800
VR4orceCJ's Avatar
Cool
No disrespect meant as I'm an AMSOIL guy myself, but you don't know what you're talking about for this application. When you've spent the tens of thousands of dollars on transmissions and gear oil to actually test each new theory like Marty and I have, then we can talk. For now guys, if you seriously track your Evo, put a cooler on it regardless of what gear oil you use.
Doc
Old Jan 15, 2009 | 07:38 AM
  #801
VR4orceCJ's Avatar
Cool
Originally Posted by razorlab
VR4orceCJ runs a SCCA mandated sized trans cooler core.
Sorry haven't been following this thread since I did the 5-speed swap. The tranny cooler that SCCA allows is the Setrab: SET616600 Series STD 16 Row Oil Cooler - 13" x 4 3/4" tall and mine is mounted in the front upper grille just in front of the radiator.
Old Jan 15, 2009 | 08:32 AM
  #802
555R's Avatar
what thread number is the parts list again for the cooler?
Old Mar 22, 2009 | 11:48 AM
  #803
andrewzaragoza's Avatar
see post 516, 524
I just wish there are shops/vendors creating a kit for this.
Old Oct 12, 2009 | 06:41 PM
  #804
mc14's Avatar
I track my mr... jus blew the trans
Old Oct 12, 2009 | 06:44 PM
  #805
voidhawk's Avatar
welcome to the club ... any details? What failed?
Old Oct 12, 2009 | 07:01 PM
  #806
Badog's Avatar
I track mine pretty heavily (no street driving at all). Destroyed 3rd gear. I now have a Shep stage 2 5speed and love it.
  #807
smack_evo's Avatar
broken 4th or cooked 3rd-4th slider?
Old Oct 13, 2009 | 03:54 PM
  #808
GST Motorsports's Avatar
I forgot to update this thread (I was razorlab back then)
I destroyed my second 6 spd right at 60k, so another 30k. I guess 30k is all I can get out of these things. Two down... wasn't going to try another....
Finally put a 5spd in and haven't looked back.
Old Oct 13, 2009 | 07:54 PM
  #809
mrfred's Avatar
I with the 5 speed had a wider gear range. I really like the cruising gear on the 6 speed.
Old Oct 13, 2009 | 08:20 PM
  #810
I cruise at almost the same RPM with the 5spd. I haven't noticed any difference to be honest
