Watch your stainless brake lines
Old Dec 24, 2006 | 05:08 AM
andyktlee's Avatar
Pocket Mo
So lazy Brian.
I'll be making sure I keep my SS lines away from the boot. Thanks for the heads up.
Old Dec 24, 2006 | 07:55 AM
chris mccarthy's Avatar
SS Lines
Sorry, my apologies, i was responding to your words from my e=mail, Warrtalon, i didn't see the context of your reply, and seemed to be flippant on a subject that has turned personal to me. i've got Works lines and though they seemed "Works Quality" it's causing me alot pain=no driving time.
Old Dec 24, 2006 | 08:06 AM
Warrtalon's Avatar
For reference, every event I've ever done was on stock lines. I just got my SS lines last week - I hope they actually improve my braking.
Old Dec 24, 2006 | 08:22 AM
what lines?
i've read many posts of yours and feel i know very little of this car's potiential compared to you. so to hear that much of your time has been on stock lines is incredible.
as far as the brakes themselves, have you upgraded them? would you tell me what Lines you finally chose?
Old Dec 24, 2006 | 08:30 AM
nothere's Avatar
warmpepsi, do you have a roll cage? if it is bolt in, the nuts go slack over time and can cause the popping sound.
Old Dec 24, 2006 | 08:34 AM
Warrtalon's Avatar
I have Centric slotted rotors, Hawk HP+ pads, SuperBlue ATE fluid, and stock calipers. I'm not sure on the brand of the lines, but I'll find out. The whole thing is a brake kit sold by VIP Garage (one of my sponsors), and they supplied it all to me. I've actually done all my events on stock rotors up until now, and most of those events were with stock pads. I only recently got the Hawk's and have done one event where they made braking FAR EASIER. I've had fluid in there from the very beginning, though. In the future, I'll get some track-only Hawk pads while relegating the HP+'s for daily driving, and I'll bump up to some Motul, since I have a feeling I'll be killing my brakes with the new setup.
Old Dec 24, 2006 | 02:39 PM
WarmPepsi's Avatar
Nah, mines from the strut tops not being properly lubed, and tensioning the spring under minimal load, and the helper spring turning and popping. We fixed it once, but since i know thats all it is, theres no point in pulling it to just lube it up to get it to do it again a few weeks later.
the bolt in rollbar is tight. Used the locking paste and double nutted the bolts i used.
Old Dec 24, 2006 | 08:27 PM
GregGSC's Avatar
Originally Posted by WarmPepsi
yeah, umm, i dunno how to tell people this. I'm running stock lines.
theres no reason not to. I bought the aftermarket ones, had an issue with the brass fitting (duh), and never put them on. 24 track days later, still on stock lines.
lol funny thing is our car is on stock lines as well. btw ALL the cup cars are on Stock rubber lines, 24 hour races 1 full season and yup still on stock lines. why? cut one open and see what you find inside.
When I was down at PRI a couple of weeks ago I asked Stoptech where the hell the 6 piston front, 4 piston rear kit is for the Evo. I was telling them how we are on Stock Calipers using Girodisc 2 piece rotors. and we hadn’t had a problem yet but I want more brakes in the car so Leh can push it harder. So he breaks it all down for me. This just made so much sense to me i figured i would share it.
The Stock Brembo rotors are POS for road racing no shocker to most of us. The funniest thing is all of the direct replacement brembo, Centric/SportStop, Powerslot ect are the same. The way the stock rotor is designed it is meant to keep rotor warranty to a minimum. Does it cool well; nope actually holds a lot of heat in the rotor. the venting on the outer part of the stock rotor doesn’t vent much heat. this gets the entire rotor hot which will help keep excess build up of pad material that causes warped rotors or warranty claims.
Old Dec 25, 2006 | 08:20 AM
meanmud's Avatar
What about future plans for the 6 piston front, etc?
Old Dec 25, 2006 | 10:07 AM
GregGSC's Avatar
They said they are working on it. they said they will not do a 4piston rear for the EVO. so if they offer a rear kit it will be a 2 piston st22 setup with the 6 piston up front. I would expect it next year 08 sometime. if it shows up early great. Ever sence centric bought them they have been working on OE Stuff.. so we got to wait.
As far as why they arnt offering the 6piston 4 piston setup here was the answer.... Stoptech designs brake systems around some factory components. such as the ABS system and the master cylinder. running the 4piston rear with a 6 piston front would cause a soft pedal. With the piston size in the rear of the car the front would have to be increased and the master couldnt keep up...
Old Dec 25, 2006 | 10:25 AM
RedOz03's Avatar
Ouch!
I had one of my braided lines start to rub on the weights on the back side of the rim. No damage just glad i caught it when it started to hit.
97laxlude
Feb 28, 2017 07:11 AM
Johnr352
11
Oct 15, 2014 07:59 AM
AyoJon!
23
Nov 10, 2010 03:06 PM
manofhonor
Oct 1, 2008 08:52 AM
mikeneri
Nov 4, 2007 08:17 PM
