Watch your stainless brake lines
My driver side rear SS line ate a hole in my CV joint boot and splattered axle grease everywhere. Mitsubishi is currently out of stock for the $60 boot kit until November and I had no choice but to buy the axle kit for $500.
I recomend you tie up your SS lines so they do not rub on the CV boot.
-Kyle
-Kyle
Kyle, if I'm understanding you correctly - the SS line simply rubbed a hole over time in the weak CV boot?
When the wheel is straight, do the SS lines touch anything inside the wheel well?
please check your lines and make sure they are tight and tied up away from the CV boots.
-Kyle
Originally Posted by kingkyle
Yup... the rear driver side line was hanging maybe 1 inch too low (too much slack) and under suspension compression, the line being abrasive cut a nice hole in my boot. I would have never thought about this until it happend.
-Kyle
-Kyle
Just one other thing to check if you have coils with an external reservoir.
SS Lines
same thing here, the lines were slightly longer and i didn't think of them interfering. i go all four boots but don't know how to proceed to install. is there anyone who can load the Manual pages for the repair? one write up here said to go from the diff side..? but i think it would be best to take the whole axle down and loan the boots and grease then install. BUT HOW?
brake lines
"...aftermarket..." what the hell does that mean? are you telling me you race stock lines, and that everything 'aftermarket' is bad.
although i may have suspect lines, i noticed immediate response from SS lines, in both pedals. i would suggest changing the lines to anyone, you just have to be extra cautious. the thread on the NorCal forum is pretty good, a little bias
Chris, who are you responding to, and what are you attempting to refute? If you're responding to me, I simply answered MikeSchultyz's question of whether these were aftermarket or stock lines. Obviously, our cars don't come with SS lines, so the ones in question are aftermarket. I don't think anyone here said that there is anything wrong with the aftermarket or that people shouldn't use SS lines, unless there was a post deleted that I missed.
yeah, umm, i dunno how to tell people this. I'm running stock lines.
theres no reason not to. I bought the aftermarket ones, had an issue with the brass fitting (duh), and never put them on. 24 track days later, still on stock lines.
