Autocross EVO - Street Modified Build
Old Jan 30, 2007 | 02:52 PM
  #76
Slowride's Avatar
Originally Posted by EVOlutionary
Already installed.
Is it SM-legal? I thought it effectively changed a suspension mounting point and was illegal, like the Whiteline anti-lift kit for Subarus.
Old Jan 30, 2007 | 03:11 PM
  #77
kekek's Avatar
I had the Mitsu dealership do it at the same time they were installing a new clutch. I think they said the hardest part was getting the ball joints separated from the spindle.
That sounds odd. Separating the spindle from the balljoint/LCA is very easy on the evo. Now if they were talking about pressing out the OEM ball joint then I would think that would suck, especially since the LCA is aluminum...if you screw up there goes $300....
Slowride said: Is it SM-legal? I thought it effectively changed a suspension mounting point and was illegal, like the Whiteline anti-lift kit for Subarus.
It is most def legal. In SM you can modify any part of the suspension as long as the pick up points at the chassis remain the same. this part interacts between the LCA and spindle, as well as the steering rack to the spindle. Although Daddio had asked a year or so back about slightly relocating the steering rack and he was met with a firm negative.
Old Jan 30, 2007 | 03:41 PM
  #78
mannymartinez's Avatar
its something im highly considering. i wonder if its something i can do my self or just drop off it at a shop for a couple hours...
for the price on these kits i think i would be worth it for sure.
Old Jan 30, 2007 | 07:43 PM
  #79
EVOlutionary's Avatar
Thanks for the clarification - that's what I meant - getting the ball joints out of the control arms was the hard part. . .
And you are correct, suspension is pretty much unlimited as long as you use the stock attachment points on the frame/subframe of the car. You could (and some have) run full aftermarket a-arms and rear control arms that have all spherical bearings instead of poly bushings, as well as quickly adjustable camber and caster. Hell, you could even have custom Titanium spindles/hubs built to save a TON of weight off of each corner. . .
One thing I don't think you can do is modify or replace the stock front subframe even if all the mounting points are the same. If you could, and someone built an aluminum or titanium subframe that would also save a ton of weight off the front of the car. . .
EVOlutionary
Old Feb 1, 2007 | 08:59 AM
  #80
kekek's Avatar
Originally Posted by SS RX7 r2
I know who bought the BSP championship car :O
I just found out today....looks like BSP won't be getting any easier. I took a peek through the back of my 2006 rulebook, and if the new owner is who I think it is, well they have lots of titles and the rest of the class will have their work cut out for them.
Hopefully it takes him some time to figure out this AWD thingy...like maybe it'll click for him in October!
Old Feb 1, 2007 | 12:04 PM
  #81
SS RX7 r2's Avatar
After one run they pretty much had it figured out last Sunday. Private Test n tune with a lot of national champs were there.
Old Feb 1, 2007 | 12:51 PM
  #82
Yeah, with that car there really isn't too much to figure out. You just point it where you want to go, hit the gas, and hold on!!
Old Feb 1, 2007 | 01:50 PM
  #83
markdaddio's Avatar
It's not really a secret as far as I know. Just say it. It's Tom Berry.
Old Feb 1, 2007 | 03:32 PM
  #84
CoreyR's Avatar
Nice.
Old Feb 1, 2007 | 03:35 PM
  #85
broeli's Avatar
Yeah. I was kind of wondering myself why the owner of a well prepped car would be a secret.
Old Feb 1, 2007 | 04:26 PM
  #86
griceiv's Avatar
2007 solo rules, section 16.1.F.1:
Steering components, including the steering rack and/or box,
tie rods, idler arms, power assist devices, and related components,
may be replaced, added, moved, or removed.
Old Feb 1, 2007 | 04:53 PM
  #87
Moving just the steering rack looks like it is OK, but moving the whole front suspension subframe in order to move the steering rack is a no-no.
Old Feb 1, 2007 | 04:59 PM
  #88
SS RX7 r2's Avatar
Hey Mark,
I think it was more of a surprise thing for the first local event. I was asked to keep it on the down low. Can't wait to see your Evo at HPT.
Old Feb 1, 2007 | 05:43 PM
  #89
Wow! I just looked through the 2007 rule book list of champions - looks like Berry has ALOT of championships between solo and prosolo. Didn't count to see who had more, him or Daddio. It sure is great to have so much racing experience behind the wheel of the EVO.
I predict great things for the EVO at Nationals this year. How many 1st places do you think the EVO will take this year? 1? 3? More??? I predict 3 . . . but I'm not saying what classes
EVOlutionary
Old Feb 2, 2007 | 11:12 PM
  #90
mov_ovr's Avatar
Hey Mark,
Now that the cat's out of the bag, I know Tom will have tremendous fun with the car in BSP. He was loving it at that first weekend. I already asked him for the car back to no avail. Rick, I think you should take a closer look at it for some tips since it'll be closer to your neighborhood. You know how I still feel about your west coast wing and the other tweaking you had to do in Topeka.
It was great to hear Mark coming back to solo this season with the car continuing to improve. I'll be taking on a new class this year, that's still being finalized with some special parts under review.
John.......
