product review: Takspeed Ti brake pad backing plates
Recently I acquired a set of Takspeed's titanium brake pad backing plates. At a Laguna Seca outing in November before getting the Ti plates I experienced some minor fade even after a fresh bleed. Laguna is hard on brakes and the DTC60 pads were starting to wear down - this minor fade didn't happen when the pads were thicker.
Before a trip to Thunderhill last weekend I installed the backing plates and experienced no fade on the same worn pads. The ambient temp was similar to Laguna in November.
I selected Takspeed because they have the widest selection of fitments for this product - they're the only ones who make a Ti shim that fits the RacingBrake 4piston calipers I use. The product fit perfectly in the caliper and is very thin and lightweight.
Ti makes a good insulating metal because it's light, strong, has a terrifically high melting point, and has a much lower rate of thermal conductivity than aluminum (on par with stainless 304).
I'll be using them from this point forward: recommended.
Sounds good, but for 99% of us, the stock calipers, although color changing, are plenty fine. However, best of luck out there.
Something i've found i'm doing is now heel/toe'ing nearly 95% of the time, and it's caused me to ride the brakes a touch longer, getting everything a touch warmer.
Just something to keep in mind when dealing with brake heat.
Some of our calipers at work have a trick little ceramic insert that pops into the piston and helps quell heat transfer. They seem to work really well. I'll see if I can find out who makes them.
20gmr
Jun 13, 2010 12:56 PM
CityTireOnline
Evo 'For Sale' Suspension / Brakes / Handling
Aug 17, 2009 08:06 AM
BlackTrack
19
May 1, 2008 09:33 PM
EVOBrakes
119
Nov 20, 2007 07:41 AM
