Ralliart Autocross setup?
Old Feb 8, 2007 | 08:28 PM
AustinG's Avatar
First post, woot!
I've found tons of info on Evo autocross setup, but not much on the Lancer.
I'm looking to setup a Ralliart for STS. I realize that it is not going to be competitive nationally or regionally, I'm just looking to have fun locally with my possible D/D. I have an 80% STS prepped neon that I have raced for the past 5 years which has been very competitive and tons of fun.
Early Thoughts for Lancer:
TEIN SS Coilovers
Larger rear sway
Poly suspension bushings (if available)
16x7 or 17x7 wheels/stickies (Azeni or Z212's)
Road/Race ECU piggyback
I'm looking for more detail on coilover setup and alignment settings. Can someone point me in the right direction? I don't know much about these cars yet, but I I'd like to get 2-2.3 degrees negative camber with a FWDer. Are the TEIN's camber adjustable or will I need camber bolts or camber plates?
Any information or advice would be excellent, thanks in advance!
Old Feb 8, 2007 | 08:34 PM
ambystom01's Avatar
For coilovers I wouldn't go with the teins, they're very pricey and do not come with camber adjustability. Ksports and Megans both come with upper pillow mounts and front camber plates and I'm fairly certain they are both cheaper than the Teins. For sway bar, I believe RRM sells a larger unit.
Old Feb 8, 2007 | 08:52 PM
AustinG's Avatar
Megan Coilovers are cheaper, come with upper pillow mounts/camber plates andare fully adjustable. Thanks!
Old Feb 10, 2007 | 02:23 PM
AustinG's Avatar
Ok, not much info. Is it safe to follow the Evo STU build for suspension setup? Guess I am going into uncharted waters here.
Old Feb 10, 2007 | 04:28 PM
Warrtalon's Avatar
No, you have to pick whatever class you plan to run in and mod accordingly.
Do you drive a Neon or a Lancer?
Old Feb 10, 2007 | 04:52 PM
DaWorstPlaya's Avatar
There is an auto-x setup thread in the Lancer forums for lancers .... check there
Janko Ralliart
Mar 22, 2013 01:10 PM
goofygrin
Sep 11, 2008 12:41 PM
N20Lancer
Nov 7, 2005 08:05 AM
EVO8LTW
37
Sep 27, 2004 09:23 AM
jbrennen
Sep 14, 2004 02:11 AM
