Ride height/body roll pics
Thx Andrew, I'll look into that Whiteline piece because as you said, going backwards would not be good!
I measure a bit differently--from the bottom of the rim to the fenderwell--it still translates...
Spring rates are 10k/8k
Looks good, your nice and close to the cones
How did you do at this event?
Here is a great little tool from Microsoft to resize pictures
http://www.microsoft.com/windowsxp/u...schelman2.mspx
its really easy to install and use
Not very strong... The closest car was a full-tilt STi, which had a run within 7/10ths. The next fastest car overall was a full second behind him...
We always have speed-maintainence course @ that a runway site. It's going to be very difficult to achieve PAX FTD as the fast drivers (National level) in G Stock Mini Coopers S cars (the new turbo) do very well on those course types and have a relatively soft PAX.
We'd (SM) have to clear them by abt 2.5-3 secs on a 35-40 second course to PAX #1--only in the rain will that happen IMO...
Are your SM cars FTD @ your events?
THey are not the FTD but they are pretty strong, here are the top results from the last event, sorry about the format. I would like to run an event in your area one day.
time pax time
ss111Burger, Steve2001 Corvette Z0649.283*0.848 41.792
as575Rankin, Kolin05 Subaru WRX STi 50.759*0.838 42.536
sm21Gutierrez, Gustavo06 SUBARU STI 49.842*0.856 42.664sm121Siriani, Sergio2006 Mits EVO 9 MR50.043*0.856 42.836sm719Velazco, Maxy2006 Subaru STI 50.308*0.856 43.063as327steinhoff, bill2000 honda s200051.524*0.838
ssl11Clark, Joan2001 t Corvette z0650.922*0.848 43.181
sm216Duncan, Krishna2003 Mits EVO 850.618*0.856 43.329
as801Ramirez, Omel2005 Subaru WRX/STi51.932*0.838 43.519
time pax time
Good question Andrew--I'd like to have the car sit like my STi does on those RCE springs you guys carry that are on the car
Seriously, I have the camber nearly maxed on the Megan adjustment, although I've not done an alignment (just by eyeball) yet, as we're working on final ride-height adjustments.
The car handles very well as-is, but I would like to lower the Cg a touch more as the car carries alot of weight up high w/ the sunroof & my heavy torso
I'm thinking longer studs on the front to allow a larger spacer as to not interfere w/ the coilover perch & go another 5/8" all the way around. The rears s/b no issue as the fender rolling did the trick.
I saw a pic of Daddio's car that was in DC @ the Pro & his car is significantly lower...
Admir, I gave the car a chance as I replaced those Tien S-techs w/ the stock springs & the car just came alive after that (it handled worse than a minivan w/ those springs
Don't worry it's being put to good use & it's tearing everything up down here
)Don't worry it's being put to good use & it's tearing everything up down here
The added toe-in on the front makes the car want to wash out in sweepers under any kind of power. This last course had a nice, open sweeper on the turnaround, but I had to wait quite a while before I could add power.
Good observation Boder
You're absolutely spot-on... I haven't done an alignment on the car yet as I'm trying to get the final ride-height set, and I don't want to keep going back for multiple alignment$...
http://www.longacreracing.com/catalo...id=152&catid=5
You can do all of the toe alignments you want for $60. It's pretty easy. It only takes about half an hour per front or rear. The only rule is that you make the same adjustments on both sides(assuming your toe alignment was straight to begin with).
If you change your camber via camber plates between street and AX/track duty, you can make marks on your tie rods. Make sense?
