Super Lap Battle - Street Class EVO
I can't really comment on the Falken but I ran Street RWD for all of 2007 on the Bridgestone RE050A Pole Position and loved them. I won 2/3 time attacks on them as well. When I got the EVO I put on the RE01R and I must say that they just aren't as good. Now, this past weekend, I also got to do a little testing with the un-released 140 treadwear Toyo R1R street tire and they blow the Bridgestones out of the water. They run about 10mm wider than advertised though so be aware of that when they come out. I will be running them next year in the Street AWD class.
n
I have yet to see a head to head comparison between what I would consider the top three "Street" tires (based on results at our Time Attack events):
Falken 615
Yokohama Neovas
Bridgeston RE01R
Up until recently, the Falken 615 was winning just about every one of our Street Class divisions at every event.... The Neovas and the RE01R are relatively new, and more people have been using them, so that means that more people will win with them, not necessarily that they are a "better" tire than the 615.
If those three companies want to donate a few sets of tires each, I'm sure I can find a car to do some testing with. :-)
Falken 615
Yokohama Neovas
Bridgeston RE01R
Im curious about the new Hankook 140 tw tires....
n
im surprised you say this... just one look at the 50A's and you can see the tread grooves are alot bigger... I just have a hard time believing they are a faster tire than the RE-01R's which are claimed by Bridgestone themselves as their top of the line 140 TW tire... but then again I have not done back-to-back testing.
n
n
Traction rating is for "wet roads."
"Traction Letter
This letter indicates a tire's ability to stop on wet pavement. A higher graded tire should allow you to stop your car on wet roads in a shorter distance than a tire with a lower grade. Traction is graded from highest to lowest as "AA","A", "B", and "C"."
http://www.nhtsa.dot.gov/cars/rules/.../brochure.html
Bigger tread gaps = better "wet" traction. Generally not so good for dry race track...
JW
"Traction Letter
JW
^^^Ahhh good to know. I had heard it was based off of the tire's ability to stop a car, but they must have left out the wet part. Thanks that actually makes more sense to me now.
Also, here is a shot of the new Toyo R1R...
You mentioned the toyos were better gripping than than the RE-01Rs, first lap or for the session due to heat tolerance? How do they compare to your Yok A048s?
Thanks
As for RT-615s winning Redline events in street class, look at the # of competitors - very, very low. If you put 15 competitors in that class with half on RT-615s and half on RE-01Rs, you're not going to see many RT-615s at the top unless the cars (or drivers) are just that much better. No one even thinks about running those tires at the National level in SCCA street tire classes.
I'm surprised to hear EgoKiller say his RE050s were so much better than the RE-01Rs, because the RE050 is no competition in SCCA street tire classes either.
But, I was way faster in the Evo than the Camaro due to the overall grip level of the whole combo. I wouldn't attribute much of what I felt to the tires due to the two completely different platforms though.
Anyhow, I hope there is something better than the RE01Rs since they are pricey and nowhere near an R compound.
I read your blog, how much time do you think you lost by lifting for sound? I think even though you have a 5" exhaust tip, you should be able to shove a 3" turn-down into the smaller inner muffler core. We did that at Quallcom by by wrapping heavy wire (coat hanger) around the muffler hanger, then hose clamped the wire to the turn-down.
Thanks
Thanks
The Toyos had a little better heat tollerance than the RE01Rs do and the overall grip and feel was better as well. They are not as fast as the A048s obviously, but they are not as far off as you would think I am guessing. I am hoping to bring all 3 sets of tires to a track soon, or at least the two sets of street tires, to do a back to back comparison. I would also like to get some tire temps, mess with pressures, and do a big write up soon.
Isn't it difficult to compare tires when you are running them on two completely different cars? If you want to talk in those terms, I've run the 615s on my Camaro and found that they stuck very well for street tires at VIR and Summit Point Shenandoah, and they also didn't seem to overheat at all. By comparison, when I ran those tracks in the RTAs on RE01Rs in my Evo, the tires started fading after 1-2 laps from heat and there was a lot more understeer and lack of good turn-in response compared to the Camaro.
http://www.hankooktireusa.com/product/Z212.pdf
Am I missing some other Hankook? The 214s on my car for the Evo vs Sti shootout were listed on the website as 200tw:
Nils,
I'd like to think the Hankook were the new best thing (cause they are pretty affordable). Hope to see someone test them in a comparison to Bridgestones and Neovas.
