SCCA Rallycross beginner
Old Feb 10, 2008 | 08:49 PM
xturdfergusonx's Avatar
Wheelgap!! what front brakes are you running? Been wanting to figure something out for the fronts to run 15's and dirt tires. I have a few small ideas bouncing around, but I figured I see what you did.
Old Feb 11, 2008 | 06:01 PM
WheelGap's Avatar
I had a custom Wilwood setup made, and then AMS came out with virtually the same thing and cheaper: http://www.amsperformance.com/store/...roducts_id=811 You might need to run a small spacer with this setup depending on your wheels. I run a 10mm spacer and longer wheel studs for safety -- I think a 5mm spacer is the most you can run on stock studs.
You can also get Euro Evo RS brakes, which are a bit cheaper than the AMS setup: http://www.z1auto.com/prodmore.asp?m...ng&prodid=1934
There's obviously expensive solutions out there like the recently homologated Brembo brakes, but unless you are interested in stuff like that, I won't go into those.
Here's a closer view of my brakes:
Eurus
Jun 17, 2016 08:03 PM
ninjacoco
Oct 17, 2012 04:52 PM
Subi.convert
North Texas Evo Club (NTEC)
May 11, 2011 05:52 PM
WAM
Mitsubishi TC-SST Discussion
11
May 20, 2010 09:39 AM
machron1
Northwest Region
10
Aug 15, 2005 01:21 PM
