silver state
Old Sep 2, 2008 | 09:51 AM
wshihdnevo's Avatar
^Tranny cooler?
Old Sep 2, 2008 | 10:30 AM
JohnBradley's Avatar
Derrr...I have all the part numbers for what it needs to get done. I think Billy and I are wondering IF it needs to be done for that short of race. I might ditch the tilton pump and go NASCAR on it instead though...Or use an ACD pump...something.
Old Sep 3, 2008 | 11:30 AM
Billy@EnglishRacing's Avatar
Originally Posted by wshihdnevo
^Tranny cooler?
I was looking for a little more detailed answer, such as is it needed, what would you go with if it is needed ect...
Old Sep 3, 2008 | 12:28 PM
wshihdnevo's Avatar
I would go to a performance tranny shop around here and get one custom made. On another note I have said parts to donate to this car.
Old Sep 3, 2008 | 01:46 PM
What parts? Pm me
Old Sep 3, 2008 | 03:31 PM
jid2's Avatar
I'd figure out a way to data log the oil temp in the tranny. Then go for a few test runs and see where you are at. You should be able to review a graph of the test run and based on the profile of the temp see if you have a problem with extended periods at speed.
Old Sep 3, 2008 | 03:56 PM
wshihdnevo's Avatar
^True, that may be easier and cheaper and = less weight Good idea Jared.
Old Sep 3, 2008 | 05:29 PM
I should be able to use the 5v input from where my fuel temp input is (rather than log the second IAT like mrfred had originally intended) and log it in Evoscan even.
...Or make it easy and get a tranny temp gauge and just watch it at a track day
Old Sep 3, 2008 | 05:34 PM
wshihdnevo's Avatar
That sounds good to me...
Old Sep 3, 2008 | 05:39 PM
the easy rout is for losers
Old Sep 3, 2008 | 05:44 PM
wshihdnevo's Avatar
^That sounds easy and smart to me. Just get a good gauge and make sure its all hooked up right.
Old Sep 4, 2008 | 08:07 AM
jid2's Avatar
To feel good about the extended time at WOT I think the data log with graphing is critical. Looking at a gauge is a nice starting point and better than nothing for sure. But the real key to seeing what will happen over extended periods of time is to review the slope of the line on a graph from some shakedown passes.
If you can find an area to sustain high RPM and speed for just a couple of mins you can then review the slope of the line. If it's still climbing you have two options: go for a longer test and see if it ever flattens out, or realize you have a cooling problem. If the shakedown shows the temp flatten out within a few mins you are good to go, assuming it flattens out at an acceptable temperature.
Old Sep 4, 2008 | 01:36 PM
For tranny temps do you think it would work the same if we logged in a lower gear but a higher rpm?
Old Sep 4, 2008 | 02:03 PM
jid2's Avatar
You should be able to figure that out with some testing. Try running at a high RPM for a set time in a couple of the lower gears and see what the difference is.
What's the top speed of the class you want to run? Does it look like you are in 4th near Redline or in 5th? There's less stress on the car in 5th probably because you aren't revving as high.
Old Sep 4, 2008 | 03:03 PM
wshihdnevo's Avatar
It will prob be in 5th...
