Recommend me some brake pads (AutoX & Track possible?)
I've got the adapters so I can run VIII/IX pads, so they don't have to be X specific although if I could get away from the adapters I'd be pleased.
Right now I've got Ferodo DS2500's and they are "ok" (but VERY loud) but they are about gone. On the track they simply get roasted slowing the heavy X down from high speeds.
I'd like to not have to buy 2 sets of pads (one for track and one for AutoX). Is there one pad that will work well for me?
I'm looking for heavy initial bite and the ability to handle heat. I was smelling pad yesterday on a 48second autocross course by the end of the day.
AutoX I run r-comps and track I run street tires (Star Specs for now, NT-05s before May).
I'll likely be 350hp or less for the foreseeable future (ya I've hear that before!).
I was thinking Hawk HT10's...
I'm a little concerned about rotor wear. I've already had to resurface my stock rotors (at around 13k miles). I figure I'll get another 6-8k miles on the stock rotors and I'll resurface them again if they are still in spec or replace them. I'm not concerned enough about rotor wear to accept worse braking.
Street and autox I LOVE the porterfield R4-S. They won't stand up on the track though. Mine have 30k miles and 3 yrs of autoxing and still have material. No warped rotors, nothing. Moderate dust.
There really isn't a pad that is perfect for autox and track. For autox you want something that has good bite at lower temps. For the track you want something that will take more heat and work best at higher temps. A pad that I have used with pretty good success at both is the Hawk HP+ though. With 2 piece rotors, good brake fluid and the factory brake ducts they worked well for track days and autox.
Here is what I am doing/have done for the last few years:
AX/Street:
Front - GranSport GS5's (like the DS2500s in terms of grip - zero noise though)
Rear - Axxis ULT's
Track:
Front - swap in Hawk HT10's
Rear - Axxis ULT's
I only swap out the front pads. At least for me, the rears never got as hot as the fronts (IR gun).
AX/Street:
Rear - Axxis ULT's
Track:
Rear - Axxis ULT's
I burned up some HP+'s on the track, I also charcoaled a set of Ferodo DS2500's on the track. I am going to use PFC97 race pads (which are HT-10's) Same company, same pad, different names on the boxes, don't ask me why. I don't have any experience yet but I have heard good things about wear, heat range, and pedal feel. They are noisy though from what I hear, so I prob will not run them on the street.
Performance Friction and Hawk are not the same company. Nor the same pad.
https://www.evolutionm.net/forums/ev...ct-thread.html
HP+, DS2500 - not track pads.
you dont feel ferodo is a track pad?
i love the ds2500 for track use... we use it alot..
ive done development brake testing for Hawk, Performance friction, Ferodo, and a few others...and all carbon testing...
you need to decide what "characteristics" you like or dislike..
for me, the ferodo compounds always have the best engagement and release behavior...
cb
cb
I have IR gunned my brakes after a cool down lap (duct here too) at 900+ F. The DS2500s MOT is 1000F - so under laps I would have more than 1000F - out of the DS2500's range.
I agree on the characteristics - I've had sets that didn't feel great to me, be it bite or release.
I could peddle Hawk DTC-30s some more in this thread, but since you don't care about rotor wear and you have a porky X on R-compounds, then I think DTC-60s or 70s would work well.
They will EASILY stand up to whatever punishment you can throw at them for auto-x or track, but you will probably be going through two sets of rotors per set of pads (this is the case on a Z06, anyway). They will also cover your entire car in dust after every event and make tons of noise.
The DTC-30 (or maybe a Carbotech XP8) will be more road-friendly and is a better dual-duty pad, but you will sacrifice some bite and they aren't rated for as high of temps.
