Tire Pressures- Road Race
Old Jun 3, 2009 | 10:52 PM
Protostar1's Avatar
Originally Posted by goofygrin
more pressure in the rear helps induce oversteer/help the car rotate. That will depend also on your suspension and alignment too. Find something that works for you
Some drivers I know run 10# differentials F/R to help with alleviating understeer.
The Evo is very front heavy and understeer is a big issue. Thanks for the start point. I will play with pressures from there. I will probably be inclined to keep them higher and sacrifice a little grip for increased life on a street tire.
Originally Posted by Wicked E
Might be an off topic stupid question but what tire pressure gauge are you track junkies using? I'm looking for a highly accurate digital gauge for both my road tracking and drag racing set ups. Please advise with links.
-E
I have a very large manual gauge from Griot's. I also have a small digital gauge from Griot's as well. As far as I am able to tell, the manual gauge is very accurate and very easy to use but it is an impact tool for a compressor tank.
Old Jun 4, 2009 | 06:40 AM
Bster13's Avatar
http://www.mcnews.com/mcn/technical/200511gauges.pdf
Old Jun 4, 2009 | 10:24 AM
Protostar1's Avatar
Interesting, I believe I have an updated version of the Griot's compressor pump tire pressure gauge. Scored a 19/20
Old Jun 4, 2009 | 07:19 PM
Protostar1's Avatar
I am going to start between 36-38psi hot and well see how things go tomorrow!
Old Jun 8, 2009 | 06:54 PM
anthony_86gt's Avatar
For me it all depends on the track. Mid-Ohio I can run them lower than say Putnam. Some tracks are really rough and eat up the tires. At Mid-Ohio I start with 36F and 34R.
Old Jun 8, 2009 | 11:15 PM
Protostar1's Avatar
For an NT05?
I was running really high like 44F 39R. I will adjust to blacktack's rec of 36-37 hot (apparently direct from Nitto) next time.
Old Jun 9, 2009 | 08:13 PM
Akisan2's Avatar
I just went to PIR with nt05 last friday.
They get HOT very fast. I primarily ran 33psi and it was 41psi when I was done with 20 minutes sessions. I ran like 80% of my abilities too!
I then put it down to 31psi and it got to 38 PSI, but I don't think this would be a good review cause it was raining on that session
My buddy ran 31PSI all day long and he was booking. He really liked the tires and he seemed to be liking his tire response...so there ya go. Our take
Old Jun 14, 2009 | 03:54 PM
05mazdarx8's Avatar
A common misconception on tire pressures is that alot of people use them to change handling and thats not the tires job. You should adjust tire pressure for the tires optimum grip and adjust your suspension to change the handling characteristics of the car. Thats why you spend all that hard earned $ on your ADJUSTABLE coilovers. Just my humble opinion
Old Jun 14, 2009 | 04:57 PM
goofygrin's Avatar
so... all those people that are playing with and adjusting tire pressures are totally doing the wrong thing? For wholesale changes, you obviously tweak your setup, but for fine tuning you have to touch the tires.
Old Jun 14, 2009 | 11:51 PM
vaughany's Avatar
We start at 28psi. It grows when hot to about 36 and we bring it back to about 32. As people are saying get a feel for the car and try different things.
Old Jun 19, 2009 | 11:19 PM
Protostar1's Avatar
I am hardly a pro racer so I am not "one with the car" but I was running extremely high pressures last time at the track and I felt the car was a bit "ponderous". It seems to be skipping around a lot. I am headed back to the track tomorrow (mainly to watch the Red Line testing!) and will dial the pressures into 37psi hot all around. Ill let yall know how things go.
Old Jun 19, 2009 | 11:22 PM
Protostar1's Avatar
I gotta agree with this. Tire pressures have a ton to do with grip on various surfaces and their fine tuning is totally necessary. Assuming you had an identical track with two different materials, you would want to adjust the pressures to optimum traction like someone posted earlier. Likewise two tracks of the same material and different composition of bumps and corners would require remapping of the coilovers. They are just responses to different things.
Old Jun 19, 2009 | 11:23 PM
Protostar1's Avatar
What tires is this for? The tire seems to make a night and day different because Hoosiers need 40+ hot and NT05s need mid 30s and I have seem some Advans needing low 30s.
Dbar4G63IX
Jul 24, 2010 03:56 PM
Inprogress
11
Mar 4, 2008 12:15 PM
dave_evolvix
16
Sep 15, 2007 07:57 AM
SSKILLA
Oct 2, 2005 01:10 PM
rt turbo
Nov 10, 2004 09:32 PM
