Tire pressure
Re: Tire pressure
Originally posted by SSKILLA
Whats the best tire pressure to run on a evo with the stock tires?
Re: Re: Tire pressure
Originally posted by Krazy Kat
32psi front, 28psi on the rear works best. Great traction and nice drift without loosing it if pushed over the limit.
Any other opinions on this subject? I am currently running 39/35 and the car handles geat but ride blows. I am going to the track next friday and am curious about good tire pressures for 60's. Thanks
i used to never lower my tire pressure till recently. I run 34/32 for normal driving with the stock advanes. i can normaly muster up a 1.8xx 60' with spin most of the time. i lowered my pressure to 27/27 and did 1.72, 1.74, and a best of 1.70 last week. so i guess for me, i works good at 27/27.
Lowering tire pressure for drag launches has a very minor effect on tires that are "normal" for an evo8. Our low profile 45 and 40 series tires cannot absorb much innitial shock becuase of the stiff sidewall, and that is what lower the pressure helps with. It helps a little up to a point, and then becomes detremental. probobly in the low 30psi range is where you see no traction gain from going any lower. Getting the tire too low on pressure distrorts the tread shape.
As Warrtalon said, it's extremely track condition dependant. Impossible to give anything buy a generl guidline.
arnold16890
19
Jun 14, 2005 07:25 PM
