Towhooks: Talk Pros and Cons About and Show Your Setup
Old Dec 8, 2009 | 01:56 PM
t3gr4's Avatar
I think WRX's can get away with the hood tow hook b/c of the hood scoop, but I dont see it going on my evo
Old Dec 8, 2009 | 02:12 PM
BoostedXevo's Avatar
I actually like the concept.. but the cutting part just kills it
Old Dec 8, 2009 | 02:47 PM
06whitemr's Avatar
looks bad *** on the sti but for my MR. nope. I rather put it on the front. n also the rear.
You dont see a lot of Evo fix up over here in the south bay area. So putting on the tow hook front n rear would be sick....
Last edited by Smike; Dec 8, 2009 at 02:55 PM. Reason: One thread, not two right after the other.
Old Dec 8, 2009 | 04:17 PM
I see a lot here in carson...
Old Dec 9, 2009 | 12:16 AM
spdngdragon's Avatar
A friend of mine thought up a neat solution to the front towhook issue. It requires a little fabrication and buying a screw in towhook like the one for the EVO X. Instead of bolting a plate of steel in the slot of the bumper beam, you bolt in a piece of steel that you drilled a hole into and tapped. This way when you don't need the towhook you don't have one hanging off of the front of your car. When you need it you just screw it in to the tapped hole in the piece that you bolted into the bumper beam...I think this is what I might try to do. If I end up doing it, I'll post pics.
Old Dec 9, 2009 | 03:14 AM
Smike's Avatar
Originally Posted by Q8_EVO
Smikevo AGAIN hasa great write up on both front and rear
i was going with T1R fronts.. but for 120 i ll make my own or buy one off ebay
https://www.evolutionm.net/forums/mo...on-w-pics.html
Merged with other tow hook thread and moved to Motor Sports. The guys here can give some good inputs. I give the general dimensions in there. A metal shop should be able to pop two of these out and some backing plates for peanuts. Too bad HLM doesn't make them anymore.
( that old house garage was such a mess. New garage is way cleaner and organized!)
Old Dec 10, 2009 | 03:09 PM
mouseIX's Avatar
any others out there? hot laps website link in SmikeEvo's DYI post is no good. Are they still in business? I am going to try to fabricate my own based off your pictures. I will post up once I get around to it, LOL. One of my many fabrication projects that I have not been able to get around to. Oh well, getting ready for my first HPDE!! Woot!! Road Atlanta here I come!!!!
Old Dec 10, 2009 | 03:11 PM
Smike's Avatar
They are not in business anymore. But I gave measurements if you want to have your own fab'd.
Old Dec 10, 2009 | 03:17 PM
Protostar1's Avatar
Smike's install worked well for me, it was pretty easy. However, those hooks from HLM were not stainless... they rust rather vigorously.
Old Dec 10, 2009 | 03:19 PM
Smike's Avatar
Yearly tradition to re-spray paint If I still had my Evo, I was going to PC them.
Old Dec 10, 2009 | 04:14 PM
Smike EVO what are those dimensions? What material did you use? What is the assumed load rating?
Old Dec 10, 2009 | 04:32 PM
htsai14752's Avatar
is the bumper beam strong enough to place a tow hook? or should we attach it to the frame of the car
Old Dec 10, 2009 | 04:43 PM
delongedoug's Avatar
I was just thinking about that. I'm sure it's strong enough, but I plan to use the chassis (I also plan to remove my crash beams is a big reason why).
Old Dec 10, 2009 | 05:08 PM
AlwaysinBoost's Avatar
I like Kyles setup but I think its more for a race car, I would be tearing my shins up on that thing. a street car IMO needs a removable tow hook, even better a folding removable tow hook.
https://www.evolutionm.net/forums/sa...treet-use.html
it worked the one time I needed it, which happened to be the HPDE right after I installed it, go figure. it was bent into an oval instead of a ring from the tow truck driver yanking on it, but it still works fine.
I leave it in my center console and just screw it in when I'm on track, its on my 'to do' list. haven't banged my shin yet.
Old Dec 30, 2009 | 05:55 PM
willitas34's Avatar
I tried looking for Hot Lap Motorsports Front Tow Hook, but it seems like the web page is down
Anyone know where I can find something similar?
