rear brake pins
Old Jul 18, 2010 | 07:57 PM
riksride's Avatar
rear brake pins
I did 2 track days at Pocono this w/e with new rotors and pads. I noticed a hell of a lot of squealing the entire time although the pads worked fine and chaulked it up to a new compound I was using.
When I went to change the rear pads to drive home, the pins and the cross spring were gone! WTF! I know I put them in there.
Has anyone ever had this happen at a track event?
Old Jul 18, 2010 | 10:05 PM
TrackEvo's Avatar
Brake pins
Yeap, happened to me at Thunderbolt. I called Zeckhausen and got everything new.
Old Jul 19, 2010 | 08:53 AM
Balrok's Avatar
Happens to most everyone when you start pushing it hard. You need to drill a tiny hole at the end of the pins and place a cotter or similar pin in it in order to prevent that.
Old Jul 22, 2010 | 06:55 PM
WarmPepsi's Avatar
had it happen once in 50+ days. Had an extra set sitting around, only lost one pin, spring was still there somehow.
Old Jul 26, 2010 | 01:13 PM
CrazedRacing's Avatar
Yeah - I had that happen after an autocross and was like
What drill bit size is used to drill a hole in the pin? Seems like you'd need a water jet drill!!
Old Jul 26, 2010 | 04:00 PM
Balrok's Avatar
whatever size your using for your selected pins, tiny basically. Also make sure you grind one edge flat so it doesnt slip off.
Old Aug 1, 2010 | 05:03 PM
WarmPepsi's Avatar
i just hit it a little harder with the punch the next (and every other time) and it never happened again...
evovirgin
Nov 8, 2015 05:46 PM
Harsh476
May 17, 2015 07:29 PM
OrangeMax
Northwest Region
19
Aug 29, 2013 05:57 PM
LaXGSR
10
Aug 3, 2010 02:10 PM
sponge bob
Mar 25, 2008 05:20 PM
