2011 NASA TT Rules
Old Apr 6, 2011 | 02:39 PM
Loser's Avatar
2011 NASA TT Rules
Just noticed this: http://www.nasaproracing.com/rules/time_trial_rules.pdf
F. BRAKES/CHASSIS
4) Add or modify other chassis stiffening devices or fabricated parts (such as lower strut braces or lower arm braces (with greater than two attachment points), subframe connectors, subframe braces, subframe mounts/bushings, etc) +3
After installing a 3" downpipe I found that one of the two horizontal sub-frame braces wouldn't fit anymore so I had to upgrade to a brace that had a kink in it to accommodate the larger downpipe. This seems like a common problem with most downpipes, but I'd hate to have to take a +3 penalty for a brace that will offer little benefit.
Anyone else have this problem? What downpipes work with the factory braces?
Old Apr 6, 2011 | 03:46 PM
Balrok's Avatar
I went through several braces, but found that the factory ones simply heated up and bent a notch around a vice works best and 0 points. Cheaper then trying to change downpipes and doable at home. Any shop should be able to help otherwise with it. But I also wrapped my downpipe (helps with oil temps a LOT) which added even more thickness, most "notched" braces weren't really worth the $ then for any performance gains.
Old Apr 6, 2011 | 05:45 PM
Loser's Avatar
I ground off about half the thickness on one of those cross members at Shenandoah where the entrance to a carousel had a steep angle (http://farm5.static.flickr.com/4063/...cb0e1a7397.jpg). So when the downpipe got in the way I ditched the OEM ones and took the chance to get a aftermarket brace. Now I gotta go looking for OEM bars again
Old Apr 6, 2011 | 06:09 PM
boomn29's Avatar
Spacers...
Old Apr 7, 2011 | 09:27 AM
Loser's Avatar
Originally Posted by boomn29
Spacers...
Nice. Simple. I like it!
Old Apr 7, 2011 | 01:27 PM
Todd06MR's Avatar
Spacers work well. I was able to use them on the eBay downpipe but just couldn't make it work after changing to a dump tube.
Honestly though, just throw the brace out. Here is my reasoning for this:
That boxed frame member has got to be super strong as it is (scientific, I know). And the moment arm from suspension movement isn't very high down that low.
Bolt bending is also increased significantly by adding spacers therefore reducing the load transfer abilities of the brace. And the spacers move the brace lower making it more susceptible to hitting stuff (this happened to me several times).
The holes through the brace are very sloppy. It would have to move significantly to transfer bearing loads into the bolt. And since the bolt is fully threaded (no smooth shank), it can't handle much load before galling the threads or digging into the brace.
Note: This analysis does not account for clamp-up forces applied by tightening the bolt. This will help, but the majority of the load needs to be bearing into the bolt.
And an added weight savings is accomplished by losing the brace.
Now, I'm sure the Mitsu Engineers added these braces for a reason, but I'm having a hard time figuring it out. I would really like/need to see some load analysis of the sub frame to figure it out.
Old Apr 7, 2011 | 01:42 PM
Alexl08's Avatar
i have a dp that works megan
Old Apr 8, 2011 | 02:42 AM
Loser's Avatar
Well, to add some scientific information to the discussion on the effectiveness of the brace, I'll see if I can do a session without it and compare the times/handling.
EGbeater
Jan 16, 2016 04:14 PM
mchristian
For Sale - Part Outs
Aug 4, 2015 08:44 AM
LCS
Sep 14, 2011 04:58 PM
ElectricBlueIX
Oct 1, 2010 04:38 PM
