Question about camber spec in shop manual
Old Jan 13, 2004 | 08:11 PM
JT-KGY's Avatar
Shop manual specifies that rear camber should be
-1 degree 00' +- 30'
does that mean maxium negative camber would be
-1.5 degrees??
or
-1.3 degrees?
Old Jan 13, 2004 | 10:34 PM
SOF's Avatar
SOF
60 minutes in a degree, so that means -1.5.
Old Jan 14, 2004 | 01:09 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Screw the shop manual, how aggressively do you drive? If you drive like grandma, set it at zero, if you drive like a bat out of hell, you might want more like -2. If you want the best handling, you need to spend some time dialing it in (starting with about -1 rear, -2.5 front). -1 to -1.5 is a general average for what kind of drivers they expect. But if you're just doing alignments, go with the shop manual.
