Front / Back Suspension Height Difference
Old Jan 8, 2012 | 05:44 PM
EvoJoeRacing's Avatar
I know that the front of the evos sit a little higher then the rear. Is there a specific guideline or ratio for the height difference? I am redoing my suspension and just want to make sure that my height adjustment from Front to Back is correct.
Any guidance is appreciated.
Old Jan 8, 2012 | 05:49 PM
R/TErnie's Avatar
Look at your virtual centers and it will become apparent.
Old Jan 8, 2012 | 09:01 PM
honda-guy's Avatar
measuring from the side rail jack point, my rear is about .5" higher than front.
Old Jan 9, 2012 | 05:16 AM
Robevo RS's Avatar
Call it a rake. It is important for handling. Different hight front rear or equal is important for a race - set up and the surface you are attempt to run. It should be a part of tge wheel aligment you get or you do.
Old Jan 9, 2012 | 08:36 AM
Its a bit of an illusion. The front fender gap gives the appearance the front sits higher, but its not.
Read this thread if you have the time. There are a few experts that chimed-in
https://www.evolutionm.net/forums/ev...bout-rake.html
Old Jan 9, 2012 | 10:02 AM
XcreatonX's Avatar
Thanks for the the link. Some good info for sure that will be helpful setting up my car for next season. I would like to see some more input about corner balancing and rake.
Old Jan 9, 2012 | 11:22 AM
EVOizmm's Avatar
I try to achieve a level "looking" rake. I then Corner Weight the car with the car in its "race" mode (Gas tank half full, me in car, ect...). And last, I do my alignment.
My CW:
I shoot for the front left/right to be equal more than a 50/50 cross weight.
Old Jan 9, 2012 | 12:09 PM
R/TErnie's Avatar
^ very similar to what I ended up with, but your front weight is a bit lower than mine. How much do you weigh?
Old Jan 9, 2012 | 12:20 PM
EVOizmm's Avatar
I'm 160lbs.
Old Jan 9, 2012 | 07:26 PM
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
Great thread, going to have to re-read that when I have time.
The only thing I think I really learned about setting up an Evo this year, is if you're going to do anything to the diffs, do that first, and then set up the suspension. I just did the OEM re-arrange and it had a really profound affect on the car, to the point where I feel like I have to reevaluate a lot of the suspension choices and see if they still make sense.
Old Jan 9, 2012 | 07:55 PM
R/TErnie's Avatar
Originally Posted by EVOizmm
I'm 160lbs.
damn you're fat.
Old Jan 10, 2012 | 08:47 AM
^ Lol... Thanks for all the input guys. Keep this going. Lot of good info being tossed around here.
Old Jan 10, 2012 | 05:01 PM
R/TErnie's Avatar
IMO... I set the instant center of the fronts where I feel is optimal based on kinematics, because it's the grip limited end of the car. After I set the fronts; I adjust my rear roll center to achieve the desired "flick-ability."
I need a custom set of uprights and then I'll get the front end super low....and bring the back end with it, bringing my CG instantly lower.
Old Jan 10, 2012 | 08:20 PM
psushoe's Avatar
Let me know when you figure that out. Until then I'll be rockin' the drag launch appearance while sitting still
I actually have used a similar strategy for my ride height. I set the front based on suspension geometry and then messed with the rear to get the feel I wanted. Going to have to redo this spring after the whiteline roll center kit goes in, but will start at last years end point.
Old Jan 10, 2012 | 08:42 PM
R/TErnie's Avatar
I've got it figured out... I just need to money to buy a huge chunk of 7075. I've got a 5-axis Mazak awaiting material...
