HPDE track tires?
The r888 can also be non-directional in the dry. They are only directional if you need the rain water evacuation. I verified this with Toyo and run them backwards to even out tire wear when needed.
I'm again shopping for tires and I'm leaning towards the nt01 simply because they don't seem to heat cycle out like other r comp tires I've tried....
Bfg r1
Hoosier r6
Hoosier koni slicks
What id REALLY like to know is how much better the nt01 is over the newer street tires like the RS3. Some claim the old compound rcomps aren't even as good.
Bfg r1
Hoosier r6
Hoosier koni slicks
Hoosier R6's are another incrmental step better than NT01's. I actually think they wear at least as good as the Nitto's, but offer more grip all around. IMHO, the NT01's were a great 'bridge' tire between the star-specs and Hoosiers.
Now the A6......
Although like you mentioned, the middle is wearing faster than the edges so I was trying to get the pressure as low as I could before rolling into the sidewall. I'll try to pump them up next to see what happens which is very contradictory to what one would normally want to do.
Mine is close. I have more camber up front, but the rest is almost identical. I have been starting off with about 30-32psi cold which hit into low 40's hot. The tire seems ok to me at that pressure but nothing special.
I targeted 38 hot. How much pressure you will gain depends on track, ambient and how hard you drive. I would start my fronts at 28-29, rears at 32 and end up real close to 38 all around.
mouseIX
41
Jan 17, 2017 09:06 PM
fireroasted
42
Dec 6, 2012 12:03 AM
katracer
Jul 13, 2010 10:11 PM
