Help find right brake pad for the track
Old May 1, 2012 | 03:24 PM
Kidloco51's Avatar
Carbotechs handsdown.....
Old May 1, 2012 | 08:25 PM
RB4-EVO's Avatar
Check here for the most recent review on RB's motorsports pads (XT series):
https://www.evolutionm.net/forums/ev...ke-review.html
Old May 3, 2012 | 11:39 AM
honda-guy's Avatar
Originally Posted by Tahoe55
For those who wonder why I stagger the pad material F-R, The RS doesn't have ABS so I tend to stagger pads to give me a little more front brake bias. I'm going to experiment with running balanced sets now and as long as I can be quick with braking modulation, I should avoid locking up the rears.
i have RS with no interior, and rear is really light with most of the weight removed from the rear. when i first got the car, it had ST43 front and rear. i was running Hoosier R6 and the rear locked up so easy. it's unproductive to try to modulate rear lockup because you're not using full bake force of the front. i kept going to lower rear compound till i ended up with street pads for rear, which seems to balance the brakes out. problem with street pads is although the torque is low, they just can't seem to handle the heat.
i'm now looking at installing a proportioning valve for the rear so i can run race pads that can handle the heat but lower the brake force in the rear.
KOOLER
Jul 28, 2016 05:10 PM
Lightsaber
Oct 9, 2013 12:56 PM
richardjh
14
May 26, 2011 08:32 AM
hamflex
May 5, 2011 08:55 PM
aeroweenie
Mar 12, 2008 05:42 PM
